Hi, Couple of quesitons... Can i just double check I've got the mounting orientation right for the gold stub axle cover (191501639B). It's been some time since I took it apart and I can't quite remember. As pictured seems correct to clear allow the disk to clear the ABS sesnor (mk3) My second question is that my mk2, non abs, had the same gold cover however when I look at part diagrams it says I should have version 191501639A which looks like this - which part is correct for the mk2 disc brake GTI? I am confused becuase I was certain my mk2 was still as it left the factory, the stub axles themselves were stamed VW Audi. Part no ending A is readily available however the one ending B is obsolete and hard to find. If it is the one below assume it mounts in a similar fashion the the pic above if that is correct, thin diameter part faces the stub axle backing and the larger diameter part cups the back of the bearing cover on the disc? Thanks! Matt
Pretty sure the shield is right, as when I've undone the bolts in the past if rotted it looks like a thin washer is on the bolt. That was 6n2 from memory. Secondly, admittedly I didn't read really in depth, but I remember there being something similar yesterday in @Zender Z20 thread, and how he modified them.
https://www.clubgti.com/forums/index.php?threads/isaac-1992-mk2-golf-gti-8v.291869/page-9 About 2/3 way down.
Nice one dodgy i will check it out. It is a shame the first one is obsolete as is also on Corrado and is needed for reinstall of disc to space from abs sensor! Im sure a machinist could knock it up but difficult without a part in hand
Perfect seen it and I'm also running meyle on mk2 so may have to mod. Luckily the mk2 non abs version of the cover is readily available to buy.
