Hi all I am busy with the family Rivage while on "home leave" Its had a couple of weird things happening following a flat battery that led me to looking for bad grounds in the dash area First up the fuel pump relay played up and then the roof electrics did the same, roof now fine but i suspect low battery voltage together with a bad ground made the fuel pump relay unhappy Anyway i have it all back together but while the fuse box was loose i suspect a spade connector came off the back and i dont know where it should go Any ideas its a single spade and the cable is blue/grey ? Many thanks Cheers Guy
this sounds like the spare dash illumination feed, it will normally be left off its for adding accessories later
