can anyone show me what every relay is for, same with fuses and ecu pins? checking with multimeter if ECU has continuity, i have put - on bare metal and + to any of the pins to see if that sensor works? sorry im bad with electrics
ECU relay is 30 in slot 3, fuel relay is 67, 80 or 167 in slot 12. fuse 18 for the fuel pump and lambda, and fuse 15 is for ISV and 2nd ignition feed for ECU (ECU relay power is different wire and is unfused)
