Seat options for Caddy
Discussion in 'Styling, Trim and Bodywork' started by MillSpeed, Oct 27, 2005.
  1. MillSpeed Forum Member
    Cambridge
    Howdy folks! I've just bought a rather distressed Caddy & the seats are absolutely mingin'. I'm lookin to replace them as cheaply as possible, so what are my options? Does anyone know if mk2 or mk3 polo seats will fit?
    Cheers,
    Chris.
  2. Armour
    Armour Forum Junkie
    Scotland
    If it's a mk1 caddy, and mk1 & 2 Golf, Mk2 & 3 Polo, Scirocco or Corrado seats will fit or if it's a Caddy van, mk3 Golf and mk4 & 5 Polo seats will fit.
    Alan
  3. MillSpeed Forum Member
    Cambridge
    Cheers for that Alan, yep it's a Mk1 Caddy. Looks like I'll be hunting down some mk3 polo seats!
  4. Admin Guest
    yes they will
  5. Gareth83 Forum Junkie
    Wales
    thanks very much!!
  6. GazzP87 New Member
    Could anyone help me!? Sadly my polo 6n2 gti has recently died and it’s going to cost me a small fortune to fix. It’s immaculate with low miles. So I am going to keep it. I was thinking of upgrading the interior. So I will have a spare set of seat. Steering wheel and gear shift. I’ve recently purchased a mk2 caddy. Does anyone know what would fit in the caddy from the polo? Ideally seats and steering wheel. Thanks for any help.
  7. rubjonny
    seats and wheel will go yes, as will mk3 golf ones. up front caddy is based off the same platform as the ibiza and polo saloon/estate, so much so people have bolted ibiza front ends onto them for something a little different
    GazzP87 likes this.
  8. GazzP87 New Member
    Will the seats literally go on the same runners?
  9. rubjonny
    yep direct fit.
    To put your mind at rest, caddy base frame is 6K0881105 & 6. Same part is listed for polo saloon/estate for poverty spec, higher spec saloon/estate use frame 6N0881105Q which is also listed to fit 6n polo hatch :)
  10. rubjonny
    actually having said that, its a caddy van right?
  11. GazzP87 New Member
    Hmm mines a 6n2 hatchback though.
  12. rubjonny
    yes the 6n0 part number is listed for polo saloon/estate AND polo hatch ;)
  13. GazzP87 New Member
    It’s a pick up not van.
  14. rubjonny
    Ah, thats a no then :( Those are based off the skoda felica/pickup so totally different
  15. GazzP87 New Member
  16. rubjonny
    see here they have seperate runners bolted thru the floor, and seats bolt to them. If you really want your polo seats to go in and you're handy at fabrication you can probably modify the old caddy bases to the polo bases
  17. GazzP87 New Member
    Luckily I work with a welder so if I decide to I will get him to do it for me. If not my friends brother does boat refitting. He’s said he could reupholster the seats and deck the bed out. So that’s an option. But much more expensive.
