Simons 89 small bumper 8v fixup thread
Discussion in 'Mk2' started by Simon Peter Dodgson, Mar 29, 2019.
  1. Simon Peter Dodgson Forum Member
    Hmm no sign of plug or white wire]
  2. Simon Peter Dodgson Forum Member
    Hold on whilst searching for plug something has gone up in smoke on the wiring to steering column stalks in the past. Rj commented on my melted headlight switch white and black switch wire earlier in thread. I wonder if that's why I have non mfa stalks?
    More melts to stalks wiring plugging into steering column
  3. rubjonny
    yeah thats a non-gti cluster harness you have there, and more destruction elsewhere so not good. I would replace it if I were you!
    I might possibly have a spare harness in stock, send me a pm to remind me to have a look for it
  4. Simon Peter Dodgson Forum Member
    Would appreciate that Rj. No mfa for me today.
  5. Simon Peter Dodgson Forum Member
    Well since mfa is on hold turned my attention to rear foglight inoperative and hunted down grey and yellow wire to behind fusebox. Not connected to anything and wrapped in green tape
    Connected wire to m which has 12v when headlight switched on
    No smoke and yay
  6. Joehough
    Joehough Paid Member Paid Member
    Well done pal, I had odd thing with my wipers, push the stalk and front wipers came on, pull it and nothing, fitted a new stalk, swapped the wires to pump around and hey presto sorted.
    Simon Peter Dodgson likes this.
  7. Simon Peter Dodgson Forum Member
    I think everyone needs a multimeter as a tool on vehicle when fault happens. Now for rear demister not working then dashboard back in.
  8. rubjonny
    pull that brown wire out of M/2!!
  9. rubjonny
    I also see a nice melted end on the blue wire, plus a melted yellow/black, I guess part of the flasher stalk wiring. all in all, a bit of a state :lol:
  10. Simon Peter Dodgson Forum Member
    The blue wire is what's connected to what's left of the white black to fusebox also running to melted black white at headlight switch. Somebody must have nicked their mums toaster cable and borrowed the neutral to rewire the meltdown.
  11. Simon Peter Dodgson Forum Member
    Just ordered a passive underseat sub kenwood.
    I have counted 20 speakers in golf when I got it with 3ways and 2 ways.have removed some 6x9 and shelf. Need a filler for bass.
  12. Simon Peter Dodgson Forum Member
    Put the kenwood passive underseat sub in today.
    Wow. What a difference. Don't run it out of phase sounds great.
  13. Simon Peter Dodgson Forum Member
    Brown trouser moment. Went to start him after few weeks. Cranking but no fire. Removed plugs cylinders full of fuel wet plugs. Spat fuel over engine bay whilst cranking . Forgot to remove ht lead from coil.
    Whoof engine bay on fire.
    Ran to get anything to put it out. Returned with washing up bowl all gone out
    Phew
  14. rubjonny
    kinda mistake you only make once :lol:
  15. Simon Peter Dodgson Forum Member
    Didn't have time for youtube vid
  16. Simon Peter Dodgson Forum Member
    Returned I fear the worst. Cylinders locked with fuel. Pulled fuse 5 so fuel pump wouldn't prime. Got it started off lift pump? after drying out cylinders. Ecu is soaking wet with this silly rain and it drips on the plug in loom as part of the cover is not there. Sump full of petrol
  17. Simon Peter Dodgson Forum Member
    What digifant ecu will I need? 89 8v small bumper. Has anyone got one I can buy?
  18. rubjonny
    any age mk2 digifant II ecu will do you :)
  19. Simon Peter Dodgson Forum Member
    Thanks Rj. Found a blown track
  20. rubjonny
    usual cause is bad gearbox earth so be sure to clean it up nice. if its earthed to the top of the gearbox bracket change to later mk2 cable which earths to a stud on the end of one of the bolts holding the gearbox on. mk3 golf a good donor for nice battery cables, grab the bolt too
