Smoke Leak Testing is now available from Badger5
Discussion in 'Badger5' started by badger5, Jul 26, 2011.
  1. badger5
    nr Glos
    SMOKE CHECK starts from 65+vat
    Identifies leaks in pressure and vacuum system. We all know how vag cars breed vac leaks!
    Biggest common fault we see with running problems, lumpy idles, fueling adaption errors in over 60% instance are caused by something leaking in the vacuum or pressure pipes.
    With this equipment we can now fully test the system for leaks. UV dye residue to find the tough to see leaks.
    SMOKE
    UV SMOKE/TRACER DYE
