I picked up an old ce2 box of loom bits for a few quid about a year ago and just got round to sorting it out lastnight. I came across some parts that i could identify (ABS loom and light looms) but also came across some bits that i couldn't. I believe they are Corrado parts based on the searching that i have done but i've not found a description of what they are for. Part numbers are: 536971282ad (labelled heater loom) 536971052AP (i believe this is the dashboard wiring, Q socket on the ce2 fusebox for the fan switch / cig lighter etc) 535971963AF (no label) 536971011AQ (i believe this is the fuel pump loom but seems to incorporate the rear lights too, so K,LM on the ce2 fusebox.) i also have an engine loom, but it has 2 of these connections on it IMG_20181121_221410 by Cragmire40D, on Flickr am i right in thinking they are ABF connections? I also have a full CE1 engine loom set, ecu and fusebox thats pretty much all in tact which is good...dont need it though any help would be appreciated.
Yeah corrado looms: 536971282ad - wiring harness for heater blower 536971052AP - wiring set for dash panel w/ 6 speakers 535971963AF - wont show in etka, pics? 536971011AQ - rear wiring harness, 9A Round plug as pictured is for the connection between mk3 headlight loom and the slam panel loom. cant say what engine its for or the ce1 bits without pics of the rest
