Hi there everyone, i have 2 little question to a while about spark plug because,i recived my golf gti from a old friend and i mounted triple point spark plug.so now i want to change that and the question is,triple o dual point spark plug is worth it in ABF engine?also why my car have only obd connector,I remember is a 1993 model,but with any bluetooth scanner I can't read nothing and no one recognize the car? I hope someone can help me, bye
use whatever bosch, beru or equivalent quality plug is listed as standard fit from your preferred parts supplier, that'll do you fine. aftermarket diagnostics tools often dont work as they only support obd comms and VW has its own protocol you can use the freeware version of vcds-lite from ross-tech, for that you'll find generic usb kkl/vagcom cables cheap on ebay and some have the 2x2 -> 16 pin adaptor included if you need one
