stub axle spacers...
Discussion in 'Chassis' started by TimE-J, Jan 28, 2010.
  1. F2 Stu Forum Member
    I deal with profile cutters all the time, 1/2 off you'll incure a minimum order charge unless they'll take a backhander
    get 10 or more done the cost of each bit goes down significantly
    what to them lupo bracket plates cost?
  2. MUSHY 16V
    aberdeen
    when i got then it was just under 10 each
  3. F2 Stu Forum Member
    if say a quantity of around 10 profiles ordered 10mm thk even out of aluminium they would be less than that and no trimming off excess bracket needed
  4. TimE-J Forum Member
    North Wales
    ordered some brackets today there 11+vat so not to bad. Thanks very much for all the help, ill let you know how i get on.
  5. l-o-m-a-x Forum Member
    Hertfordshire
    I have ordered some of these too (and the long bolts that go with it) from Citygate VW in Chalfont, but there will be a delay as they are on back order by VAG UK apperently.
    Yes, higher tensile bolts essential folks.
  7. tshirt2k
    tshirt2k Forum Junkie
    Herts
    what are the correct bolts for this then? are the longer ones a VW part.
  9. tshirt2k
    Herts
    Just to confirm. These spacers are from the lupo GTI. The Bolts are are the same as the golfs. M10x32mm. Not sure if they would need longer bolts???
    This must mean the rear brake assembly must fit also, to make changing of the disks easier too if you have 4x100 wheels.
    Please read the thread. It couldn't be clearer.
    If you take a Mk1/2/3 Golf and just buy the spacers, the Mk1/2/3 bolt length will need to increase by 9.5mm.
    The Lupo bolt needs to be compared with a Golf 1/2/3 bolt to ensure it is 9.5mm longer before using.
    Otherwise Ford bolts.
  11. MUSHY 16V
    aberdeen
    the bolt should stick about 10mm out the back of the beem on the standard gti setup
    the lupo uses longer bolts M10x40mm the part number is N 90886301
  12. tshirt2k
    Herts
    The Lupo GTI are completley different model to the normal lupo, 6E0 instead of 6X0. I have one so should know it. As not to confuse everyone else. Vw dealers aren't too helpful when you don't give car details.
    Correction on bolts.. was looking at wrong number in etka GTI bolts are the ones stated. Not all lupo's are the same.
  13. MUSHY 16V
    aberdeen
    yip the low spec lupo's have the same bolt as the golf mk1/2/3 M10x32mm
    and the lupo gti has M10x40mm
  14. Nige
    Nige Paid Member Paid Member
    Just for clarification, are the M10 bolts M10 x 1.5 or M10 x 1.25 thread ? Its a lot cheaper to go to a local hardware store for 10.9 Bolts rather than VW.
    Great info regarding the Lupo spacers, thanks for sharing that, I`ll get a pair.. :thumbup:
  15. tshirt2k
    Herts
    I think it the standard course pitch for M10 which is 1.5
    When I did this, I found the mainstream hardware store bolts in that size/tensile strength came in Allen heads only.
    That's why the Ford source is mentioned since they have a bigger underhead surface area, which I felt was more stable (esp if running shims underneath the stub axle) :thumbup:
    (& I'd be loathed to have an Allen rounding off).
  17. Nige
    30secs on Ebay found these M10x40mm 10.9 Hex Head Bolts
    I appreciate they are 1ea, not sure how much they are from Ford ?
  18. A.N. Other Banned after significant club disruption Dec 5th 2
    I originally did this conversion in 1995, and found them after giving up on the local fasteners outlet and going cap-in-hand to a company preparing Escort Cosworth rally cars. As they were Group N cars, I've just sourced them from the local dealers since, last bought a set about 5 years ago IIRC.
    Ford parts are cheap - I'd be surprised if I paid more than 10 for 8.
  19. MUSHY 16V
    aberdeen
    the right vw bolts are only about 90p each
    Right, enough.
    Some details, as without them people can't work out what's required.
    From a quick run around www.vagcat.com
    • Mk1 / OE bolt 10.9 M10x32mm / part no: N 90758901
    • Mk2 / OE bolt 10.9M10x24.5mm / part no: N 90369801
      but I also found...
    • Mk2 / OE bolt 10.9M10x32mm / part no: N 90758901
    • Mk2 Group A Rally Car (with spacers) / 10.9M10x30mm / part no: N 90068902
    • Mk3 / OE bolt 10.9M10x32mm / part no: N 90758901 or N 90877301
    • Lupo / OE bolt 10.9 M10x32mm / part no: N 90758901
    • Lupo GTI / OE bolt M10x40mm / part no: N 90886301
    • Escort Cosworth / OE bolt length TBAmm** / part no: F1640024 N/STK 009267/Bolt, Price: 1.08 plus VAT each.
    Confusing mix between Mk1 and Mk2 bolt lengths, typical parts systems.
    ** Will confirm in due course
