Sump gasket paper cork or rubber which one?
Discussion in 'Engines' started by altern8, Jul 28, 2009.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Hey
    About to change the sump on the mk2 whats the better gasket to use ?
    Paper
    Cork
    or
    Rubber ?
    Cheers
    if you get a rubber gasket you need longer bolts, I'd just use the cork gasket if staying std. you could get a windage tray from a diesel mk3 if you felt like it, but again need longer bolts
  3. penny71 Forum Member
    Somewhere
    With cork and paper gaskets I like to warm up the engine after and then let it go cold again and retorque the bolts.
    Theory being as the engine warms, metal expands and crushes the gasket a bit more.
    Then it contracts when cold leaving the gasket slightly "loose"
  4. pigbladder Forum Addict
    cambridge , uk
    id choose the rubber one
  5. vrbanana Forum Junkie
    Sunny Sheffield
    The thick card/paper type every time, OE spec on earlier vehicles. Also look at using “weldseal” works a treat on paper etc, never ever leak. Cork splits if over tightened, rubber only with windage tray or with ally inserts to stop the rubber being squashed too far and pushing it out of the side
    actually that being said i think i used a paper one on my MK2, basically whatever GSF supply. I just nipped the bolts up and never had a problem.
  7. vrbanana Forum Junkie
    Sunny Sheffield
    GSF do two qualities of sump gasket, always use the best quality, the other ones cracks
  8. altern8 Forum Junkie
    I just called gsf they said they only do the cork ones these days. Looks the same on the website too :(
  9. Matt82
    Matt82 Forum Addict
    GTI Scene
    the vw one i got for mine was rubber and only cost a tenner or so. 10nm on those little bolts and thats been fine since
  10. rubjonny
    yeah yours is an abf so it has the right length bolts already, if your car has a cork/paper on from zee factory you need longer bolts :)
  11. skint_golfer
    skint_golfer Forum Member
    Banbury
    high tensile m6x20 socket head bolts from screwfix = 2.31 inc vat for 50pack
    toffee m6x17 hex head bolts from vw = approx 70p + vat each and you need 20
    if you go with the rubber/windage option just use the new m6x20's as they fit fine although 2 will need a washer behind them. will be obvious when you fit them which they are.
  12. altern8 Forum Junkie
    Where Can I get some welshseal from?
  13. drunkenalan Paid Member Paid Member
    Leicester
    i have used the windage tray with the standard bolts no problem.
  14. vrbanana Forum Junkie
    Sunny Sheffield
    try engine reconditioners or e-gay
  15. skint_golfer
    Banbury
    tip of the day:
    do the 3 bolts at each end of the engine last as they go into ally plates and if you do them first there's a good chance you will pull out the threads.
    not that I just did it of course... [:$] :lol:
  16. Dancork#
    Dancork# Paid Member Paid Member
    Hi folks, sump gasket was leaking, have got rubber gasket and slightly longer bolts N90592703, question is do you need sealant for rubber gasket, I was thinking not but just making sure
  17. Tristan
    In theory no, but I always spread a little on both sides.
    Dancork# likes this.
  18. davidut5 Forum Member
    Romania
    I used some sealant only on the space between end seal flanges and block. Even if they are rubber if used again will leak. Happened to me on valve cover and sump.
    I read some do not use any gasket just sealant, i believe this works, i have seen on cars from factory, vauxhall combo c for example.
  19. Tristan
    That's common on newer stuff, as the surfaces are more rigid and machined more precisely. The sump on a mk2 is far too flexible though.
  20. Dancork#
    Well it's fitted anyways, used a little sealer with gasket as suggested, was straight forward as gearbox out☺️cheers for replies
    Tristan likes this.
