Sump gasket paper cork or rubber which one?
Discussion in 'Engines' started by altern8, Jul 28, 2009.
  1. rubjonny
    ElsaWin calls for a little sealant at the points where the flanges meet the block, D 454 300 A2
  2. Simon Peter Dodgson Forum Member
    I've just ordered rubber gasket and an oil pump from vw heritage. No idea what's on the pb 8v at the moment. Have you got a screwfix part number for the longer bolts just in case?
    Scrap that found them ordered screws and washers from screwfix ta
  3. davidut5 Forum Member
    Romania
    Just get some from a mk3 1.6 1.8 2.0 and more, sump is the same and all had rubber/metal gasket. If i remember correctly i have mk3 bolts and gasket on my driver 1.6ez.
    N 90008401 m6x14 mk2 cork
    N 90592703 m6x16 mk2
    N 90423402 m6x17 mk3
    Simon Peter Dodgson likes this.
  4. Simon Peter Dodgson Forum Member
    Heritage have just sent me a rubber one. Pump arrived later as was out of stock. Probably didn't need it as strainer was blocked with broken baffle plastic pieces
  5. muppet9966 Forum Member
    Uxbridge, United Kingdom
    I found my 1.6 ez engine had long enough bolts for the rubber gasket.
