Surprise, I’ve changed my swap again
Discussion in 'Mk2' started by afbiker02, Jun 13, 2018.
  1. afbiker02
    Bury St. Edmunds
    I plan on it once I find out what to use instead of Photobucket.
  2. DN5
    DN5 Paid Member Paid Member
    Doncaster
    If you become a paid member on here then you can upload directly :)
  3. afbiker02
    Bury St. Edmunds
    I used to be a member but I keep forgetting to pay my yearly fees. Lol
    DN5 likes this.
  4. afbiker02
    Bury St. Edmunds
    I finally put the mo’s on after having them for almost 2 years
    DN5 likes this.
  5. Savagesam
    As DN5 said, either become a paid member or use IMGUR :)
  6. afbiker02
    Bury St. Edmunds
    I got my 1.3 speedo cable today but I feel like I’m missing something. 174CB6C1-FC0F-4732-A513-28539ECD1AB0.jpeg
  7. DN5
    Doncaster
    That looks right buddy.
    If the current Speedo is run from an electric drive then you just unscrew the electrics from the top of it and screw in the new 1.3 end.
    afbiker02 likes this.
  8. afbiker02
    Bury St. Edmunds
    I thought there was supposed to be a gear on the end that goes into the gearbox?
  9. DN5
    Doncaster
    The cable won't come supplied with the gear but like I say if you remove the electronic gear from the gearbox then you can unscrew the plug end and screw in your new cable..
  10. DN5
    Doncaster
    This is what you should have in the 24v I'm pretty sure.
    You'll then spanner the plug off on the right of the photo/top of the drive gear and then screw in your cable :thumbup:
  11. afbiker02
    Bury St. Edmunds
    Ah, gotcha. That makes sense now.
    Next question. With the corrado pedal box, do I need any other brackets for the clutch master cylinder?
  12. DN5
    Doncaster
    The pedal box should have like a template attached to it so you can mark where you need to drill on the bulkhead. The bulkhead will need to be flattened out too with a hammer but that will become apparent when you test fit the pedal box.
  13. afbiker02
    Bury St. Edmunds
    What does everyone use for a front engine mount?
  14. DN5
    Doncaster
    On my VR6 I used a solid vibratechnics mount but unsure on this application.
  15. rubjonny
    with a VR6 front engine bracket matched to a corrado VR6/passat heavy duty front engine carrier you would use a MK3 golf type mount, for mk2 engien carrier and vr6 front bracket you would need a MK2VR6 type solid mount.
    for the mounts I would start with OEM VR6 stuff and see how you go (except for the front if tyou need the MK2 VR6 conversion mount obviously)
    Actually saying that may have to modify the front bracket anyway same as the r32? if so you can adapt it to suit a mk2 oem mount at the same time. the mk3 front mount sits a bit higher and tilted backwards vs a mk2 one you see, so if you try to fit a mk3 front bracket on mk2 mount it pushes the engine up and backwards
  16. afbiker02
    Bury St. Edmunds
    Does anyone have any pictures of a mk2 front engine mount modified to fit an R32 engine?
  17. afbiker02
    Bury St. Edmunds
    6541558D-D48F-4122-A531-1E0CF5CA9736.jpeg 1BFC4B3B-735B-4CA2-AF37-74E56A95D292.jpeg BD3FA0A2-117C-4786-9C48-F625B19D623B.jpeg Stuff happened
    DN5 likes this.
  18. afbiker02
    Bury St. Edmunds
    What does everyone do for heater hoses?
  19. DN5
    Doncaster
    I used a mix of some odd mk3 bits and also some pipes from a site online. Google custom coolant hoses and you'll get a good idea
  20. smi2710 New Member
    I to am deciding on doing this swap on my newely aquired mk2 and taking my mkiv gti 24v and swapping it all in. EUROWISE in NC is making a kit now to mount he VR in stock MK2 setup with out having to gather all the different subframe kits. I was hoping to retain my 6spd but looks like a 5spd is just a much easier swap and will still allow me to utilize my current driveshafts. i know theres a ton of lists out there for the swap but if anyone has on to put in here as to parts needed to gather before the start of this as i will use the eurowise prefabbed mounts to save time and sourcing of the subframes etc..
