Surprise, I’ve changed my swap again
Discussion in 'Mk2' started by afbiker02, Jun 13, 2018.
  1. afbiker02
    Bury St. Edmunds
    Does anyone have pictures of how they have mounted the dbw pedal?
  2. watercooled Forum Member
    Nelson,New Zealand
    Good point John mentioning the tach adapt,Bob Ashlock is a really good guy and his units are bulletproof unlike the MSD product that fails,I used Bobs unit for my 914/6 Porsche,had a few questions and he helped me ASAP and also helped me setup a trick ignition system.
    Wow this conversion is going to make one fast car,I have driven a 24V Eos and they are a really nice motor in a heavy car,in an MK2 it will be be a different story.
    afbiker02 likes this.
  3. afbiker02
    Bury St. Edmunds
    Can I use the 12v vr6 coolant housing on the 24v?
  4. afbiker02
    Bury St. Edmunds
    Stuff happened 7BA6D654-4447-4261-9616-CCC3DEABC2E6.jpeg BE55631A-D2C9-4353-BE8F-E932B52ED1C5.jpeg
  5. DN5
    DN5 Paid Member Paid Member
    Doncaster
    How are you tackling the loom?
  6. afbiker02
    Bury St. Edmunds
    My friend that is helping with the swap is doing all the wiring for me. The plan is to have this running this weekend. I hope my hoses come in this weekend to as that’s all that will keep me from driving it but there not meant to show up until Monday :(
    These came in though
  7. DN5
    Doncaster
    Never seen a lower arm like it!
  8. afbiker02
    Bury St. Edmunds
    There made by the same company that makes the front lower rad support I’m using, Fabless Maufacuring. They make quality parts. My friend is sturggling with the wiring. He’s trying to follow RJ’s mk4 wiring thread but it's quiet a bit different between the harness used in the thread and the 24v one we’re using.
  9. DN5
    Doncaster
    If you give @rubjonny a pm he will most likely be able to provide a link or guide for anything you need :thumbup:
    rubjonny and afbiker02 like this.
  10. DN5
    Doncaster
  11. afbiker02
    Bury St. Edmunds
    So I’ve been told to use the mk3 vr6 oil filter housing but it doesn’t have the oil cooler attached to it. I was told to use this housing for the oil press switches but what do I do about the oil cooler?
  12. rubjonny
    ah sorry its the vr6 oil cooler cap you need to swap over to clear the front bracket, I forgot that the 24v type block has the oil cooler on the side of it:
    https://www.clubgti.com/forums/index.php?threads/funkbarons-mk2-golf-24v-v6-now-breaking.173467/
    with the 24v oil filter housing you have 1 hole for the MK4 switch which you bin and swap for the mk2 white 1.8bar switch, another with an allen head bung in you you remove and switch for the blue or brown 0.24 or 0.3 bar switch. then you also need a T piece if you want the MFA oil temp to work as well
  13. afbiker02
    Bury St. Edmunds
    Awesome, that helps a lot. Thanks RJ
  14. afbiker02
    Bury St. Edmunds
    47D5B2CB-7D55-4084-8B55-244CEE9F8350.jpeg I don’t think I’ll have an issue with the mk4 oil cooler because I bought a fabless manufacturing rad support with the 24v engine mount 0B5392E9-D388-454F-AB2C-039EABCD67FD.jpeg
    Wiring getting laid out
  15. afbiker02
    Bury St. Edmunds
    Got this all wired up this weekend but couldn’t get the fuel pump to work so I ordered a new one because we couldn’t get the pump to do anything even connected directly to the battery. I got the new pump installed today after about 30 minutes of loud noises and sware words. I tire the key and I still get nothing. I hooked the new pump up directly to the battery and it comes on but not with the key. I swapped the fuel relay and fuses but I’m still not getting anything. I need to know where to look next?
  16. Sirguydo
    Bolton
    Imobilsor ?
    Do you put jet engines back in looking like that ?
  17. afbiker02
    Bury St. Edmunds
    I had the imobilzer removed and I’m using a vr6 fuel tank and pump
  18. rubjonny
    does the throttle body make any noise? if not you haven't got an ignition live to it, check fuses 17 and 18 for starters you might find one or both is missing and those power a couple ignition feeds which you may be using.
    to test fuel pump and wiring you can swap a 17, 18 or 100 relay into slot 2 which should power the fuel pump up with ignition regardless of what the ecu is doing
  19. afbiker02
    Bury St. Edmunds
    The throttle body moves with the pedal.
    We swapped the relay with a 17 and the pump came on. But we’re not getting any spark or fuel. We have power to the coil packs and the injeters.
  20. Toyotec
    The ECU only runs the pump, if there is an RPM signal. It does not send a low pulse to 'prime'.
    On 24v vehicles, a relay (428) with extra channels to say a door controller, is fitted to prime the pump prior to starting the engine.
