Swapping Seat Backs
Discussion in 'Mk2' started by PhilRyder, Oct 22, 2020.
  1. PhilRyder
    I haven't had a proper look yet but perhaps someone can give me a definitive answer.
    The left bolster on my driver's seat is fubarred but the passenger seat is fine. Is it possible to swap just the backrest part rather than simply swapping the seats left to right. I ask as I would like to keep the seat height adjustment on the driver's side.
    Thanks all.
    I have stripped and rebuilt rights as lefts, and vice versa. But that was foam off etc. But I can't see any issues, unless it's a 3dr, your tilt mechanism will be on the wrong side.
  3. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    You could just swap new foam and material from a good seat onto the metal of your drivers seat.
    PhilRyder likes this.
  4. PhilRyder
    Thanks Tristan, I can live with the adjuster being on the wrong side. I can then refurb the broken side at leisure and swap them back:thumbup:
  5. PhilRyder
    That's the plan, longer term.
    look for a 5 door seat and job done, just make sure its correct age as 84-89 different to 90-92
  7. PhilRyder
    Is there a reason why 5 door is better than 3?
  8. dodgy
    May have pair CL 5 door seats if close to Halifax, if any use
  9. rubjonny
    because 5 doors dont have holes where the tilt handle goes on a 3 door. if you use a passenger 3 door seat you'll see the hole ;)
