VAG-Com ABF Digifant label files
Discussion in '16-valve' started by G60Dub, Sep 18, 2009.
  1. G60Dub
    G60Dub Forum Member
    Angus
    Posting these here as I sent them to Uwe years ago but don't think they ever got shipped with the software. These are mine to post as I stuck them together.
    Trawled thru WinELSA to stick them together so others with VAG-Com may as well get the benefit.
    If there are updates or stuff I've missed then prob best to post
    awesome cheers :thumbup:
  3. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Looks good Al. :clap: Haven't got program on this machine. Where do you put them. Does it give better info on measuring blocks?
  4. G60Dub
    G60Dub Forum Member
    Angus
    Hi Russ
    Just dump them in the 'VAG-Com\Labels\' folder.
    If there's not a definition for a group value VAG-Com does a best guess based on the values it reads - Not sure how well it does as I've used these for the last 4 years and newer versions may be better - I only have 409-1.
  5. G60Dub
    G60Dub Forum Member
    Angus
    Theres some stuff I need to add to the files regarding the Lambda integrator values; should be able to post it up tonight; Now posted.
    I put these together such a long time ago I'm not sure what I used as an info source. This generates some concern for me as upon checking the service manual it appears there are several discrepanices with what I've posted above and what's stated in the service manual.
    I'll check and update (if required) the 3.2 file as and when I get the chance, however as I no longer have an early MK3 16V I cannot validate the first file so please be aware some of it may be manure.
  6. Matt82
    Matt82 Forum Addict
    GTI Scene
    bump because of the sheer epicness of this thread
  7. G60Dub
    G60Dub Forum Member
    Angus
    LOL... bump for ABF fury. How did you manage to dig this up Matt?
  8. Matt82
    Matt82 Forum Addict
    GTI Scene
    im dusting off my ABF. ive neglected it for the best part of 18 months.
    it feels pretty awesome at the moment tbh and i was just looking up any data i could find on the digi3.2 and this came up on google.
    with the labels vagcom will make a lot more sense as more of it just appears to repeat.
    mine is not shutting the injectors on closed throttle so i assume its a vac issue, i need to keep working ont hat though
    four refurbed injectors and a fuel pump later and its feeling far perkier. its got to be tip top for the 16v RR Shootout
  9. Matt82
    Matt82 Forum Addict
    GTI Scene
    just a quickie... fuel trim, does that reset when you clear fault codes? i need to clear the learned settings as the car has been running crap for a long time
  10. rubjonny
    i dont htink there is any 'memory' in the abf ecu as it doesn't have a permanent live feed
  11. Matt82
    Matt82 Forum Addict
    GTI Scene
    it remembers fault codes, even after the battery is disconnected so it must remember something.
    without knowing the labels and there not being a lot of info on google about the measuring blocks i really couldnt tell what is being remembered or not
  12. Toyotec
    What did you measure in the adaptive terms to suggest you need a reset?
  13. Matt82
    Matt82 Forum Addict
    GTI Scene
    i dont even know if it keeps a long term trim, i only found the labels today, but it has been running utterly naff for ages, it has loads of new parts on there so i want to reset it.
    on the mk4 if you clear the fault codes it clears the fuel trims, any idea if digi3.2 does the same?
  14. Toyotec
    Fuel trims actually come from rear lambda sensor ( which is not present in non OBD2 or EOBD vehicles). Adpatives, which is what this label file is calling "fuel trim" is for fuel mixure lambda control and integrates into +/- offsets due to errors in the intake charge such as leaks, purge and so on.
    If you suspect your car is not running right or the adaptives have been offset significantly then you may have other issues.
    Not something that you have to guess about really. Such hook up VAGCom and observe the measuring blocks.
  15. G60Dub
    G60Dub Forum Member
    Angus
    Taking it through basic settings resets the trims
  16. rubjonny
    just had a look in elsawin and there is a procedure to match the ecu, throttle body and isv together which i didnt know about. cant be that important though i never have and it made 166bhp :lol:
  17. Matt82
    Matt82 Forum Addict
    GTI Scene
    ill try and load those labels and have a peak now that i know what the boxes are for.
    the car seems to be in quite rude health so bring on the RR day
  18. Matt82
    Matt82 Forum Addict
    GTI Scene
    copy n paste!
  19. rubjonny
  20. Matt82
    Matt82 Forum Addict
    GTI Scene
    was just looking through that site....
    golly, that looks complicated :(
