What Will Vibratechnics Mounts Do For You ? Their rubber-to-metal bonded products are designed specifically for high performance applications where a direct replacement for the standard mount is required along with a much higher level of engine control to cope with higher engine outputs and higher road inputs caused by fast driving. The Fast Road mounts give significant improvements in ride and handling without adversely affecting vibration isolation. The competition mounts also eliminate clearance problems with strut braces and exhaust systems, body panels etc. and improve handling whist still giving vibration isolation at high engine speeds. Competition mounts are not recommended for road use Send us a PM for a quote with the part number from the above chart!
Now available through the website! PM, or email for any queries or anything that you cant see listed! http://www.jtechperformanceparts.co.uk/vibra-technics.html
