Vw Mk2 Jetta Coupe 4motion Build. (Recent Photos Added)
Discussion in 'Members Gallery' started by waj27, Apr 18, 2018.
  1. waj27 Forum Member
    Putting it all back togther makes such a difference going on clean
    Savagesam and erreesse like this.
  2. waj27 Forum Member
    Had all the subframe and suspension bits shot blasted and i then painted them with epoxy
    Had to get a little creative to paint them
    Building the subframe back togther
  3. waj27 Forum Member
    Next was to build it back and have it on wheels. Shell was at another unit with a little more room
    And rolling
  4. waj27 Forum Member
    Had the interior also done, went with Mk5 Golf interlagos fabric on the centres with black saude
    Before
    Couple interior bits i did myself
    cupracraig and erreesse like this.
  5. waj27 Forum Member
    Tailgate plinth lock delete
    Hated the look of the tailgate springs that had to go
    Can't avoid an RS photo these sat in the loft for a few years
    Still have the A8 Winter wheels and the G60 Splits to finish off
    Had some rear popout windows made quite hard to get hold of but worth it. These are no an electic popout switch desided manual is to much work.
    the switch
  6. waj27 Forum Member
    Front Brakes and Lines. went a bit OCD, with Porsche Brembos with 312 discs its mega tight behind 16s
    Made some braided line also
    Electric Pas pump
  7. waj27 Forum Member
    Had a go at doing my own Westy front bumper which turned out alright but sadly had to cut up a rear jetta small bumper :(
    And on the car with new chrome inserts
    benthejettaman and erreesse like this.
  8. waj27 Forum Member
    Did away with the mk2 door handles went for MX5 handles try and clean up the look.
    Had bought some smoothed doors but didnt like the idea of not having a handle to get in the car. The amount of filler they used
    And the Duckbill
    Originally the plan was to have the tank on the underside but it made the exhaust situation really tricky so opted for in the boot which i have also covered in interlagos fabric.
    How i had mapped out the tank and exhaught before
    In the boot now with the filler pipe also in the boot.
    To run the tank with external fuel pump meant i needed main pump and a lift pump to supply the main pump, drew up the serge tank at work got someone to weld the bits for me, went with a walbro 255 for the main pump and a Bosch external pump from an Audi for supply.
  9. stevencooke Forum Member
    Excellent work., loving the interior and attention to detail. Can I ask if you just used normal body filler on the smooth boot plinth and bumper, thanks.
  10. waj27 Forum Member
    I used plastic flexible filler on the bumper and just normal body filler on the plinth but if you have reinforced the bumper great with no flex you can get away with normal filler
    stevencooke likes this.
  11. benthejettaman Forum Member
    some where in the uk
    Hi great work, may I ask where you got your rear pop out made?
  12. waj27 Forum Member
    Got them from a company in Poland Forty Five Vag
    benthejettaman likes this.
  13. cupracraig
    South West
    fantastic work, a really solid build this
  14. Savagesam
    Thanks for this, I want to fit some in mine
  15. waj27 Forum Member
    Cheers mate, will drop you a pm at some point in the summer when this lockdown is done as you are only 25min or so much my house would love to see yours in person
    Have you seen VW Heritage ? you can get some for a Golf for like £30 a side where as i paid over £300 for the pair being a coupe its all different from B pilar back.
    https://www.heritagepartscentre.com...ss-clear-left-3-door-for-pop-out-windows.html
  16. Savagesam
  17. cupracraig
    South West
    Blimey! Every time you see them they’re mega price.
    now to find some hinges! Thanks a lot[/QUOTE]
    if you find the hinges, let us know! :)
    Savagesam likes this.
  18. waj27 Forum Member
    What you need is 106 or 206 Popout hinges plenty at the scrap yard, thats what i used and they fit perfect, tho i then changed the closing hinge to electric popouts might actually have a set of standard for both of you :)
    cheeky vid
    https://www.instagram.com/p/B5dg25fHfIn/?utm_source=ig_web_copy_link
  19. Savagesam
    Now that, is really really really cool.
    if you do, let me know a price. I’ll send it over :)
  20. cupracraig
    South West
    So those are electric units from a 106/206 then? having the electric activated ones is pretty sweet, nice modding!
    If you have a set of parts that would be ace. Would also be good to compile a parts list for anyone looking to do this.
