Have a drip from the nipple which looks a bit mangled but solid. I prodded and seems solid but would like to keep it that way. Any ideas where water could be coming from? Have sunroof on my 89 8v digi small bumper. Oh its parked on an incline with rear lower than front
there is a hole into the jacking point area up front for one of the wheel arch liner bolt inserts, worth having the liner out and take a look up there. if you look in the door shut area the sunroof drain pipe should poke thru a gap in the wing and into the inner wing area, worth having a good look in this area for potential rot. one other area could be a rust hole top of the inner wing at the screen corner, if bad water can make it inside the jacking point area. look art the base of the A pillar and the sills too, for any rot holes or missing bungs
