Window Regulator
Discussion in 'Mk2' started by Digi, Jan 18, 2022.
  1. Digi Forum Member
    I need a new window regulator, are 2dr and 4dr the same ?
  2. dodgy
    Don't think so, I had to do a rear one on mine, sure the fronts differed listing (obviously the 2 door doesn't have rear ones, I know I'm daft, but...)
    I'll see if I can find company I got them from, think in Cornwall, hang on...
  3. dodgy
  4. Digi Forum Member
    Thanks, I have ordered one from Ebay. The seller tells me they are the same. I will let you know how it goes.
  5. NateS2
    I'm 100% sure the factory parts are different, however the repro he has may just happen to fit in both positions
    front regs are the same 3 and 5 door, but are different for single and 2 piece glass
  7. Digi Forum Member
    Thanks John, that's what the supplier told me.
  8. NateS2
    I can't read, read your post and dodgy's at the same time and got "front and rear" rather than 2dr and 4dr, whoops [:$]
  9. Digi Forum Member
    Well, I didn't need it after all! The window jammed, I squirted some silicone spray on the rubber channel and it glides nicely now.
