Does anyone have the partcode for the metal part that holds the rubber outer scraper? On part diagrams it shows 193839477B. But he part I've received is only the rubber scraper. Thank you
193839477B is the correct part number for the rear left outer scraper seal yep, assuming you want one for the rear left door same as the slot seal the metal holder it goes in is part number 193853763B. You can use a front one from a 3 door after cutting it down a bit, the rounded angle bit is ever so slightly different but its not too noticeable. certainly less so than a nasty rotten one anyway
Ahh okay cheers! For the right (Drivers side) Would the metal holder part number be 193853764D or 193853764B? From what I can gather they're for different VIN ranges but on the drawing it also shows that the slot seal has been changed for a 3 part item consisting of 21A, 11 and 21B?
193853764D is for doors with trim strips up to 1986, 21a, 11 and 21b are the strips that fit into it. after that its 193853764B
