I have an AUE engine which will be going in my Bora. I am looking for a manual for the V6 engines, the Haynes only covers the 4 cylinder engines, any suggestions??
Haynes? LOL. If you want information on something specific send me a FB message and I can help if I not flat out busy.
It's torque settings, timing procedures and all that jazz, it would be nice to have something to refer too rather than keep googling and relying on the internet
I have done this myself and have the data that I can list here. If you need it faster than that then pm me as it will take a while to put it up here as I am busy with all sorts currently.
ELSA would be the only source for that info really. It's what the VW mechanics use so has all the info you require.
I posted the R32 supplement on Facebook a while back I have both it and the mk4 one Will post here later
This what I have it the R32 supplement for the Bentley manual you should find everything you need in there https://drive.google.com/file/d/0B1f4ZY7bX9nPbG1KX3VsZVhkUUU/view?usp=drivesdk
AUE/AQP Torques Cylinder head 30Nm, 50Nm 1/4 turn, then 1/4 turn Flywheel bolts 60Nm + 90 deg turn Bolts for cam/oil pump drive 60Nm + 90 deg turn Damper bolt 100Nm + 180 deg turn
If you indicate what it is you want to do, with the AUE engine I suspect you are transferring to your Bora, then please let us know.
