Wossner ABF Rods
Discussion in '16-valve' started by PAB, Feb 7, 2009.
  1. PAB
    PAB CGTI Regional Host
    Mansfield Notts.
    Hi all, does anybody know anyone who stocks Wossner H beam Rods for an ABF engine... they seem to be like the proverbial Rocking Horse Poo!!!
    Help please..
  2. aj_gti Forum Member
    TSR are a supplier, although to be honest they look like any other h beam rod out there.
    Have you thought about Scat or CAT rods. Both 4340 h beams, and the CAT ones can be bought for around $320 dollars with ARP2000 bolts
    I have a set going in my new engine. They're identical to the SCAT ones but a little cheaper.
    I know Hotgolfs 2.1 revving to 8 1/2k was on Scat rods with no problems
  3. PAB
    Mansfield Notts.
    Thanks for the info, TSR don't stock the longer rod for the ABF engine... real pain. Had thought about other makers, but need a real good nod from somebody who has used them before I commit to any other makes. The car is for track only and will live between 5&8K RPMs.
    I'll have a look at Scat, I've used their Cranks in Aircooled Drag race motors before.
  4. Brookster
    M1 J40
    i got my rods from Intregrated engineering in the US 220 they do everything ARP too if you need it.
    more metal in the 4340 h beams others i've used in the past plus Bigger studs too that others.
    www.intengineering.com
    they do everything for the 20VT too.
  5. PAB
    Mansfield Notts.
    Thanks, i'll check it out. :thumbup:
  6. PAB
    Mansfield Notts.
    Just ordered a set, worked out at just over 300.00 at current exchange rate.
    Thanks again boys.
  7. Brookster
    M1 J40
    did you ask him to send as a gift to avoid import tax, if the exchange rates wasn't so bad you would have got them alot cheaper, but still not a bad price.
  8. PAB
    Mansfield Notts.
    Yip, put them down as a gift with low value. Got the express postage too so that put the price up a bit $50.00. Can't wait for them to get here.
    Thanks again. Philip
