WUR doesn't have a vacuum pipe plumbed in?
Discussion in '16-valve' started by onnie, Sep 19, 2010.
  1. onnie Forum Member
    Romford, UK.
    As per title, it doesn't have a vacuum line plugged into it.
    It has a rubber bung over the inlet. It supposed to have a vacuum right? I read that the vacuum tells the WUR to richen the mixture under acceleration, is this right?
    Cheers.
    oh, car is 89' Mk2 Golf Valver.
  2. danster Forum Addict
    There should be another port on the side that has the vacuum connection on it. The one on the front is just a vent with a protective cap. :thumbup:
  3. neil kaye Forum Junkie
    england
    good point ,id like to know this too
    here is a pic of the wur vac pipe and bung,this is how its normally set up
  4. Gareth83 Forum Junkie
    Wales
    that is correct, it richens mixture under full throttle
  5. onnie Forum Member
    Romford, UK.
    And if I opened my bloody eyes, I would have seen the rubber pipe coming off the side of it. DOH!
    Cheers guys. Sorry!
  6. arnau Forum Member
    Barcelona - Catalonia
    I lost the protective cap yesterday... is that really important? there is any risk of driving the car without it???
  7. 3hirty8ight Forum Member
    No, just protects it from the elements! put a bit of tape over it if your concearned ;)
  8. arnau Forum Member
    thanks :thumbup:++
    why is it there anyway?
  9. M7R
    M7R CGTI Regional Host
    Nottingham
    :lol: dont put tape over it.... then you block the hole and it cant suck the plunger as the area behind is is now sealed.
    have a look in the scrappy etc for a new cover, or run with out... or find something else to go over it... so long as it doesnt seel the hole up its fine.:thumbup:
