’88 Fuel pumps => CE2 rear harness
Discussion in 'Electrical' started by dialdfordisco, Jan 15, 2006.
  1. dialdfordisco New Member
    United States
    I'm at the end of my VR swap, and while switching everything over to
    CE2 I've run into a snag at the fuel pumps. There's more wires on the
    CE2 harness, and they're different colors. How do I splice the plugs
    off my pumps into the new harness?
  2. VR6Will Forum Member
    is this for the lift pump, then one inside the tank? if so you need to change it for a 90 spec one....
  3. rubjonny
    Check the fusebox FAQ sticky post in this section, I think it might have the info you need ;)
