1.6 EZ wrong intake manifold ?
Discussion in 'Carburettor' started by Mk2_q8, Jun 22, 2020.
  1. Mk2_q8 New Member
    Bought the car several years ago has a 1.6 ez engine in it but with a wrong intake and carb so i ordered a new 32/34 weber, rubber flange and a used manifold but the flange seems too small to it ! Im I having the wrong mount or the incorrect manifold ?
    you also need a metal adaptor plate to fit a weber on a mk2 manifold, was that included? theres another adaptor and bracket which fits on top to allow you to fit the original airbox as well
  3. Mk2_q8 New Member
    The metal adaptor is included with the weber kit and fits on the rubber carb flange but the rubber flange is small to fit on the manifold
    right ok, can you post some pictures? once you get 10 posts you can upload direct or for now put on a hosted site.
    for a mk2 1.6 the flange should look like this:
    inlet:
  5. Mk2_q8 New Member
  6. Mk2_q8 New Member
  7. rubjonny
    think thats an SPI type manifold, if so thats why
  8. Mk2_q8 New Member
    So will i have to change the manifold or could a 2e3 flange fit in
  9. rubjonny
    you might be able to use the weber on an SPI rubber flange, but im not 100% sure on that one sorry
  10. Mk2_q8 New Member
    I'll give it a try thanks once again thanks alot Mr.rubjonny
  11. davidut5 Forum Member
    Romania
    Opposite thing happened to me, the one i ordered was too big for my ez, so indeed ez should be the smaller one.
  12. Mk2_q8 New Member
    I had the wrong manifold for the ez engine to start with and thought they were all the same
