1.8T AUM - drive by throttle replaced by cable - Which OEM ECU and loom to run?
Discussion in '1.8 & 1.8T' started by waj786, Aug 18, 2017.
  1. waj786 New Member
    I was wondering if its possible to run an 1.8T AUM running a throttle cable setup (drive by delete) on the standard ECU and loom?.... or would a loom/ECU be required from another engine code?
  2. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    Any Reason you would want to run a cable instead of DBW? did you know that from about 15 years ago pretty much ALL cars, vans and trucks ALL run DBW throttles
    I cant think of a single reason to run a cable these days, i hear people say its a proper connection, it wont break (but it does) . blah blah . but the DBW system rarely goes wrong
    Stick with dbw !!
  3. Toyotec
    For, EU3 20vT engines, torque is requested by driver demand.
    Driver demand is mappable.
    If you want a throttle cable, then find yourself an AGU package.
