Hello, I've tested injectors today and when I put everything back I've noticed this masterpiece : I have to use the car so is it possible to seal the intake pipe and the over-run valve and use it that way temporarily? This car never stops amazing me with such clever solutions
Hi mate, you cant run it without he overrun cut off valve itll stall every time you coast down If you need to use the car id try sealing it back up with whatever you have about but it needs welding properly Sent from my iPad using Tapatalk
Thanks for the inputs! Is that true that the original plastic part wasn't very durable and squeezed by the suction effect?
plastic parts worked fine , the metal tube was sold as a power roar to boy racers with too much money
