1993 vr6 obd reader
Discussion in 'Vagcom / VCDS' started by g_singh, Jul 22, 2019.
  1. g_singh Forum Member
    Hi. So i have a obd1 1993 vr6 running in my mk2 golf with the obd port attached . When i attach my Bluetooth obd device it connects but the software i use for my mk4 golf doesnt connect to the ecu.
    Does anyone know of an android app that will connect to earlier cars like mine?
    Thanks
    G
  2. GVK
    It won't work because it's not OBD2 compliant
    I think the cheapest way of doing it is VCDS lite on a lap top with the cheapy Ebay KKL cable
    I have OBD eleven dongle for Android, not sure it will work as same reason - not supporting OBD1. Ask them on their website or where ever https://obdeleven.com/en
    Do you have the 16 pin connector or the old 2x2?
  3. g_singh Forum Member
    Cheers for that gvk. I have the 16 pin connector. I mesaged obd11 earlier, lets see what they say.
    Failing that i will use the laptop and cable.
  4. GVK
    If you get a cheap cable, make sure it works with whatever Windows you use. There's a recent thread on here with the info.
