Audi BDB 3.2 DBW pedal mk2 Golf?
Discussion in 'VR5, VR6 & Wx' started by DJP, Nov 15, 2020.
  1. DJP
    DJP New Member
    Morning guys n gals,
    Which pedal is required for standard management?
    Help much appreciated!
  2. Savagesam
    You’ll need the dbw pedal modified into the golf
  3. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Is that the Mk1 TT engine? Best would be from the same car but I think the Mk4 has the same pedal plugging into a blue/red connector on the engine loom.
    DJP likes this.
  4. dodgy
    My dbw pedal bracket came from boost fabrication, more expensive than when I got one now though, but a nice solution.
    DJP likes this.
  5. DJP
    DJP New Member
    The engine is from an Audi A3
  6. DJP
    DJP New Member
    I'm not sure whether to stick with a mk5 floor mounted pedal or like '1990' said use a mk4 pedal and use the blue/ red connector
  7. 1990
    Rochdale, Lancs
    You need the right one do the age of the engine, mines a BUB engine so needs (I believe) the Mk5 or later A3 pedal.
    I’m not 100% on that though.
  8. DJP
    DJP New Member
  9. DJP
    DJP New Member
    Yep pretty much where I am.
    Anyone else?
  10. DJP
    DJP New Member
    Which engine , ecu and pedal did you use?
  11. dodgy
    I've got 1.8t from an audi S3 8L, 2001 afraid it's not a v6.
    Kept original ecu and loom from the car, and had the pedal from it too, same as a mk4 golf and tt as far as I know.
    Actually worked out the dimensions to make a pedal bracket from photos of epytec one, then literally the same night the boost fabrication bracket got listed on Ebay at good launch price, so wasn't worth me buying the metal to make one.
    Bolts on to two servo bolts and puts pedal in great position. Got the hydraulic clutch from them too, bolts straight to pedal box, neat solution with new parts, just have to sort clutch pedal switch for ecu, stops revs hanging, as well as the cruise control if fitted. They recommended using a micro switch on the pedal.
  12. DJP
    DJP New Member
    Nice, yeah i know with a 1.8t you can use virtually any mk4 platform pedal. The bracket sounds a good solution for your build.
  13. DJP
    DJP New Member
  14. dodgy
    Swap seems more popular in America, think fabless or sp do mk5 bracket, may be worth referencing
    Edit, its mk 4 and mk7 they do bracket for on fabless, mk5 suppose to mount where pedal stop is on a mk2.
    1990 and DJP like this.
  15. DJP
    DJP New Member
    Thank you for replying
  16. 1990
    Rochdale, Lancs
    Have you seen this done? I got a Mk5/A3 floor mounted pedal but have never seen one mounted.
  17. dodgy
    There is a photo somewhere out there, I'll see if can find it at break time. Seems to be more US than uk, so may be different lhd.
    What are you running on yours then 1990?
  18. Savagesam
    There’s a few floating about, search for it on Facebook
  19. rubjonny
    I made a BDB loom for a customer, since his floor mount pedal loom was cut I put a MK4 blue plug on either side and pinned it up same as mk4 so he could try both pedals. He fitted a mk4 pedal and told me it works fine :) I've also heard of someone using floor mount on a MK4, not sure how true that is but is what made me try fitting the mk4 dbw pedal loom plug on this loom
  20. DJP
    DJP New Member
    Thank you for replying, I was lead to believe a BDB was based on a mk5 platform. But if I can use a mk4 pedal happy days! So much easier too!
    Longlive the King @rubjonny!
