Brake calliper ID
Discussion in 'Chassis' started by Georgetl, Dec 16, 2023.
  1. Georgetl New Member
    Hi all
    trying to understand what callipers I have as I want to refurb them but can seem to find the part number online/it’s difficult to read I may be getting the wrong number if anyone could help me Id them please
    here’s all the information on the callipers
    54
    3560/5v**
    Lucas vw
    other side
    54
    Cn3
    3561/5
    6145 *
    Lucas vw
    the * being unreadable
    thanks in advance
    George
  2. daNpy Forum Member
    NL
    54mm pistons, Lucas callipers. That's usually all you need to know.
    https://www.autodoc.nl/auto-onderde...i-19e-1g1/1656-1-8-gti-16v?criteria[200][]=54
    Original numbers:
    1A8 615 123 VAG
    1A8 615 124 VAG
    1H0 615 123B VAG
    1H0 615 124B VAG
    357 615 123A VAG
    357 615 123AX VAG
    357 615 123BX VAG
    357 615 123C VAG
    357 615 124A VAG
    357 615 124AX VAG
    357 615 124B VAG
    357 615 124BX VAG
    357 615 124C VAG
    433 615 123A VAG
    433 615 124A VAG
    443 615 123 VAG
    443 615 123F VAG
    443 615 123FX VAG
    443 615 124 VAG
    443 615 124F VAG
    443 615 124FX VAG
    6N0 615 123C VAG
    6N0 615 124C VAG
    857 615 123 VAG
    857 615 124 VAG
    893 615 123 VAG
    893 615 124 VAG
    8A0 615 123 VAG
    8A0 615 124 VAG
    8D0 615 123 VAG
    8D0 615 124 VAG
    8E0 615 123 VAG
    8E0 615 123X VAG
    8E0 615 124 VAG
    8E0 615 124X VAG
  3. rubjonny
    most likely 256mm based on the fact there are no dimples on the outside which most (not all!) 280mm calipers have. but as danpy said it doesnt matter if they're 256 or 280 the piston seal and slider pin kit is the same
    daNpy likes this.
  4. Georgetl New Member
    That’s for your reply’s sounds like I need 54mm pistons then.
    interesting you say that about the 256 callipers as the brake discs off the car are 280 OD. Don’t know what its originally meant to have but seems like a few parts have been swapped out in this little golf’s lifetime by previous owners, certainly throwing me a few curveballs!
  5. rubjonny
    Often if car had 256 people keep the calipers as it saves bleeding them, you just use 256 pads, sometimes have to grind pins a little or use part worn pads to get calipers to squeeze over.
    That said there are 280mm castings without the dimples, you can confirm by measuring the distance from piston to caliper outer pad lip. 256 are 53mm Vs 61mm for 280
    daNpy likes this.
