Brembo 330x28 2-piece disk brake kit-5x100
Discussion in 'Badger5' started by badger5, Aug 21, 2008.
  1. badger5
    nr Glos
    new 330mm x 28mm 2-piece setup featuring lightweight aluminium brackets now.
    Rotors - 149 each
    Ally Bells - 60 each
    bolt kit - 13.95/disk set
    brembo calipers - 275 each
    caliper spacer brackets - 7 each
    caliper brackets - 55 each
    caliper mounting bolts - 5.50 each (x4 req'd)
    Braided brake hoses for Brembos - 47.50 pair
    Optional DS2500 padupgrade - 96
    Optional DS3000 pad upgrade - 108
    Motul RBF600 high temp brake fluid 500ml - 8.99
    Available as kit or components
    Prices exclude vat & carriage
    Rotors and bells are exactly as used by my Ibiza racecar (redrilled as 4x100) - Race Proven. :)
  2. tinydubs
    tinydubs Forum Member
    can these brackets fit leon cupra 312mm discs and mk2 golf 16valve 5 stud hubs
  3. GVK
    I guess this is what I really need, kerrrchinggg!! $$
  4. craggsy Forum Member
    Leicester
    Whats minimum wheel size that would clear?
  5. GVK
    Bill runs 17s on the Ibiza on 330s
  6. badger5
    nr Glos
    mk2 golf 16v 5 stud hubs?
    eh??
    is there such a thing?
    5 stud drive flanges pressed into mk2 hubs you mean?
  7. badger5
    nr Glos
    i run 17's yes, as GVK says.. but my 16" MO's also clear with spacers (my wet setup)
