Budget garage build
Discussion in 'Garages, workshops & DIY' started by 1990, Jul 5, 2013.
  1. jamesa Forum Junkie
  2. HPR
    HPR Administrator Admin
    A good way to build a garage is the use of sandwichpanels ( pur/pir) as used for industrial buildings. These are sold in B quality ( often as nice as A panels due overstock,canceled order , cut to wrong size or wrong color order or minor damage, uneven foam filled )
    These sell for as little as 20 /sq metre but of course you need a framework to get the structure, but its fast to build, looks pretty good and on isolation values its very good. ( even houses get build more and more that way )
    Collie likes this.
  3. sambo Paid Member Paid Member
    Great job Ian!
    Hahaha your mate (unpaid helper) looks like he is in pain of some sort, probably unpaid bit causes mental pain hahah
  4. mat-mk3
    mat-mk3 Administrator Admin
    Do you have a link to them Hugo? Sounds good. I wonder if it would be classed as a building or shed though for planning permission.
  5. Collie Forum Junkie
    ditto link please cant find them in my usual stores
  6. HPR
  7. Raider Forum Member
    Kingspan Make them near to me.... Whether they sell via other Outlets or direct only I don't know. I Know they sell seconds etc.
  8. 1990
    1990 Paid Member Paid Member
    This is as far as we got yesterday, I put the dormer looking bit over the door so I wont have to have a gutter over the door.
  9. Trev16v
    Great skills Ian. Wish I had done anything like that amount of work myself when mine was built!
  10. TSR 2.1 Forum Member
    Got to say that is very impressive, I know you say it is / was a budget build but that dose not for a second show in the work to date (bar the window handle) ;)
    Like the dormer addition. But why would it be a problem having a gutter over the door?
  11. 1990
    I need to build steps down to the door so thought it the gutter was there the steps would have to be wider.
    I also though about putting a sign on the 'Dads dog house' or something lol
  12. 1990
    Roof tiles are coming today, i've gone for some Irish made Quinn tiles that have a thinner leading edge than the Marley Modern. I got 400 for 327 so hopefully they will cover it.
    I've spent another 30 on wood for some extra horizontal support and the bits I cut off the rafters are the correct angle to go between the horizontal and diagonal.
  13. steve r
    steve r Forum Member
    I'm using this method for my garage, a steel frame clad with sandwich panels. 105mm of foam for the walls & roof. All covered under permitted development for an outbuilding.
    The steel frame allows a high clear roof structure so I can get a 2 post ramp in.
    Its all bolt together so could be taken down if I ever move.
    Garage is looking good Ian :thumbup:
  14. mat-mk3
    Do you have a link you can PM me Steve?
  15. steve r
    I'm buying it through a company called 3cb - Click Me
    They will design the building to your spec and can supply it as a kit for self build. They offer several thicknesses of panels and colours.
    mat-mk3 and jamesa like this.
  16. TSR 2.1 Forum Member
    Steve what sort of 2 poster are you looking at? I have been looking into these and this seams quite reasonable, and keeping in mind that I would not be using it as much as in a commercial garage, so I guess the "made in China" quality would be all ok for a few years DIY use http://www.ebay.co.uk/itm/SUPERB-BRAND-NEW-CAR-RAMP-2-POST-LIFT-ELECTRO-HYDRAULIC-CAR-LIFT-VEHICLE-RAMP-/231022804962?pt=UK_Lifting_Moving_Equipment&hash=item35ca083fe2
    But it would require a fairly substantial floor to bolt it to?
    The other option seams to be this sort of thing http://www.ebay.co.uk/itm/MOBILE-SCISSOR-CAR-LIFT-VEHICLE-LIFT-not-2-post-lift-BRAND-NEW-/261302183786?pt=LH_DefaultDomain_3&hash=item3cd6d2e76a clearly less assess under the car but seams to be a not too bad compromise? Has any one used one of these sorts of lifts?
  17. HPR
  18. steve r
    I have an old thread here looking at 2 & 4 post ramps, will update that rather than hijack Ian's thread.
    Could a Mod tidy this thread and move the ramp info?
    TSR 2.1 likes this.
  19. 1990
    The bricks are all done now, I found s metal side door on eBay for 15
    Then I figured out the spacing for the tiles which was length of rafter + overhang - length of one tile \ (rows of tiles-1)
    And then I started on the felt and lats, soon after it started to rain and hasn't stopped since lol
  20. Them bricks look nicer that my house! Can't say I'm not jealous...
