Carb Flange
Discussion in 'Carburettor' started by FreedomCore, Aug 1, 2014.
  1. FreedomCore
    FreedomCore New Member
    Milton Keynes
    Right, so I'm currently on my 3rd carburettor flange. And to be honest im getting a little bit fed up.
    I'm assuming they keep breaking due to the lack of support the carb has. I was thinking of making something along the lines of a bracket from the rocker to the carb. Like many inlet manifolds have.
    Was just wondering if anyone has had this same problem and has an alternative solution.
    Also it's a Weber carb with a bolt on filter.
  2. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    My son has the same issue on his 1.3 with the 2e carb, rubbish design
  3. rubjonny
    the 1.6 and 1.8 has one as standard, yours is just missing ;)
    it goes to a rubber bush on the front of the airbox, this may also need replacing if the stud on the front has snapped
  4. FreedomCore
    Milton Keynes
    Well the thing is, I no longer have the air box or the bracket that attaches to the fuel vapour thing. Running a pancake filter.
  5. muppet9966 Forum Member
    Uxbridge, United Kingdom
    Heres a photo if the bracket:
    ah i see, to the carb it is then! but tbh, i woudl recommend you put the oem airbox back on as the pancake one will probably lead to carb icing in the winter
    Collie likes this.
  7. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    A support bracket between the carb and a couple of valve cover studs seems like the way to go (if you are determined not to run the factory airbox). I guess you're buying non-genuine flanges? Genuine ones may be made of better rubber, but I wouldn't bet my life on it, and the price will probably be twice that of a pattern part. Not designed to work without the carb being supported though, so nothing will really last (unless you want to custom-build something out of PEEK or similar, if you really fancy a challenge!).
  8. FreedomCore
    Milton Keynes
    I would have used the original air box but the carb didn't come with the adapter plate. So it was easier to use the pancake filter. I got a flange from GSF and turns out it wasn't machined properly. So now I'm waiting for one from vw heritage.
    For now though, I'm going to use for flexible exhaust brackets.
