Cleaning Expansion Tanks...
Discussion in 'Styling, Trim and Bodywork' started by Zender Z20, Nov 29, 2023.
  1. Zender Z20
    Wouldn't go as far as saying it's a top tip, but worked in this case...
    Porsche 924 expansion bottle / bracket that came attached to an airbox, it was the Kjet gubbins I was after so everything else was just secondary.
    Still it was far to good to bin, even it's of no direct use to me, so gave it a clean up.
    Had the usual rusty stains / tide marks and discolouring you'd find inside any tank that's this old, previously I'd have spent an age poking a stick / sponge or similar through the neck to clean it, but this time tried shaking a chain around inside instead (in a bleach solution) and the below is the result, came up well I thought.
    (Chain's easy to retrieve too)
    May or may not work for you, but a lot less effort if it does and can't hurt to try.
    AKAeddypeck, Cressa and dragonfly like this.
  2. 2swe Forum Member
    Czech Republic
    I used Domestos WC gel and then gave it a bath in ultrasonic cleaner :)
