dash lights
Discussion in 'Jetta/Vento/Bora' started by vwbandit, Sep 3, 2014.
  1. vwbandit New Member
    right i got in my car tonight and the light over my speedo no longer works :(
    is it possible to change the bulb if they are changeable ???
    and also my digital clock has the bleed forming across it. is this repairable if so what is the best way or is it time to get new clocks. which will suck as its the original one that came with the car
    any help much appreciated cheers
    Nick
    assuming this is a mk2:
    http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=30719
    and a guide on stripping clocks to replace the dials, once you get this far its not much more work to get the revo face off and pdb out so you can get to the digital clock lcd to swap it:
    http://www.4130-products.com/step/install/index.htm
    as long as you get another set of clocks the same type as your originals the lcd will be compatible (pre-90 clocks are 2 plug, post-90 are 1 plug) you may even find the lcd is same pre/post 90 but I've not checked this yet
  3. vwbandit New Member
    thanks for that info and its a mk2 jetta . ill get a second set of clocks and folow the steps to change bits around all i need is a bulb for the speedo and to change the computer and digital clock :) cheers Nick
