Dead heated seat relay ?
Discussion in 'Electrical' started by mrglee, Nov 16, 2023.
  1. mrglee Forum Member
    Can someone just confirm to test voltage would be applied between pins 8&2 (should click) before I bin it as nothing happens.
    Also this relay number is 459 part number 1e0 919 533 do I have to get this one of will the 59 relay work
  2. costel1969
    Pin 2 & 8 are not the coil supply terminals, they are normally open contacts that will close when the coil is energised.
    I believe 6 & 9 are the coil contacts and if my memory serves me correctly it's a positive to 6 and negative to 9.
  3. mrglee Forum Member
    cheers costel got the relay to work positive on 9 and negative on 5 will check the seat elements and power from switch seats never worked from the day i bought it would be nice to get them working.
