DIY transmission jack adaptor
Discussion in 'Tools, Equipment & Fasteners' started by oldnick, Nov 18, 2022.
  1. oldnick
    oldnick Paid Member Paid Member
    Farnsfield, Notts
    Evening all,
    I'm changing my Ford Kuga clutch next week, and thought I would spoil myself with a transmission jack.
    Now I've seen the prices :cry: I'm going to make one myself.
    So, I have a heavy trolley jack with a hole in the saddle, a length of rebar, and a welder.
    How wide should the claws be? How much curve?
    Cheers,
    Nick
  2. GVK
    You'll have to measure the gearbox and or make it adjustable?
    I found with the universal trans jacks used in workshops that the jaws weren't wide enough and too much of an angle to lift heavy 6 spd trans safely.
  3. oldnick
    Farnsfield, Notts
  4. oldnick
    Farnsfield, Notts
    @GVK, don't spoil the dream with your inconvenient facts!
  5. GVK
    I've not done a gearbox on a Kuga tbh , but I think from memory its a Getrag 6 speed, those boxes are super heavy as used in Focus STs etc plus the extra 4wd gubbins.
    As above I would measure the box and make up an adaptor to suit.
    KeithMac likes this.
  6. oldnick
    Farnsfield, Notts
    Thankfully it's FWD, but it is 6 speed and looks heavier than the 020 that I did last time :(
  7. GVK
    Lucky for you its fwd. yeah it makes an 020 look tiny!!
  8. oldnick
    Farnsfield, Notts
  9. KeithMac Forum Junkie
    Kazakhstan
  10. Adamss24 Forum Member
    You can get proper heavy duty engine/gearbox jacks for not much money nowadays, good if you do these jobs regularly, otherwise just flog it after you done ! Beauty with these is foot jacking mechanism which lets you keep both hands on the load !
