Engine fault codes
Discussion in 'Jetta/Vento/Bora' started by brizzol, Mar 2, 2014.
  1. GVK
    You might find that you can't view over a certain measuring block with the free/sharwware version.
    It used to be block 25 on the old vag-com 409.1 I used to use on my VR6.
    MUSHY 16V likes this.
  2. MUSHY 16V
    aberdeen
    aye 08 will be it if it said measuring blocks then 208 and 209 if it will let you as gary said it may not
    you looking for the +8.0 KW to -8.0 KW bit
  3. brizzol New Member
    Bristol
    Thanks guys, ok i paid to activate my version of vcds and checked the measuring blocks and these are the results...
    Is this the right information?
  4. brizzol New Member
    Bristol
    Ok how do i upload a photo to my post?
    I cant seem to do it!
  5. MUSHY 16V
    aberdeen
    aye the -6 cf is what your looking for
    you should see the same in 209 as well but when i tested me mates r32 i had the same no reading
    try looking at 90 91 and 92 and see it's reading both cams
    is yours a 10v or 20v v5 ?
  6. brizzol New Member
    Bristol
  7. brizzol New Member
    Bristol
    Cheers mushy i will have a look at those other ones tonight, so the reading off 208 is that anything to worry about?
    It is a 20v by the way.
  8. brizzol New Member
    Bristol
  9. MUSHY 16V
    aberdeen
    is that at idle did you try rev it to see what it did
    my thinking is the chains are ever streched or the timing is out as it should pick up block 209 and it's not
    could worth swaping the cam sensor to make sure one is not faulty the allen bolts can come loose on them as well worth checking as well
    i could be wrong but thats what i think
  10. brizzol New Member
    Bristol
    That was without the engine running, just the ignition on.
    I will swap the sensors around to see if the fault moves, i will do that sat morning as i am also taking the throttle housing off to clean it because that is causing me problems as well, but thats another story...
    The blocks 90, 91, 92 what information should i be seeing, and should i do it again with the engine running?
  11. MUSHY 16V
    aberdeen
    It should be telling you what the cams are doing
    Ie you should be able to see if it is advancing the cams or not
    If it runs like a bag of nails after cleaning the throttle housing
    Doing the basic setting on the throttle sorts that
    brizzol likes this.
  12. brizzol New Member
    Bristol
    Ok latest on the lemon ;)
    Well over the weekend i had the throttle body off and cleaned it (it wasnt particularly dirty) put it back on and it was just as bad, revs very irratic going up to 3000rpm and back down whilst on tickover!
    I tried to do the basic setting in vcds but it wouldnt even let me do that, just coming up error!
    So i bit the bullet and bought a new one. fitted it last night and it works perfectly, ticks over like it should and all the throttle related errors are now gone.
    So back to the camshaft sensor problem, i swapped the sensors over tonight. cleared the errors and waited for it to come back and it did, exactly the same error which rules out a faulty sensor!
    I decided to pull apart the wiring loom housing and the whole section on that side of the engine is all taped up, (not the original tape) including the section branching off the sensor in question!
    So i am now thinking there is a break in the wiring somewhere which has been botched up in the past and has now failed again...would i be on the right track with this?
  13. MUSHY 16V
    aberdeen
    aye you could be and it should be easy to check as well
    coluld be worth swapping the the pulgs the wrong way on the sensors and see if it it can read it in the messuring blocks 208 and 209
    would tell you two things
    if the problem stays the same it is the wiring if it moves from one to the other it is the chain timing thats out
    if it is a wire it should be easy to fit a new wire between the plug and the ecu or just fix the bodged bit
    i hate other peoples wiring botch ups :cry:
  14. rubjonny
    yup get all that tape off and brace for bodgery!
