Exhaust system for mk1 caddy 1.8l 16v
Discussion in 'Mk1' started by _E_, Jun 14, 2022.
  1. rubjonny
    you'll be fine then just pop it on and go
  2. _E_
    _E_ Forum Member
    Sound, might just have to soak it boiling water to soften it up lol.
  3. _E_
    _E_ Forum Member
    Hi mate,
    Went to fit the metering head boot and there is nowhere to put breather pipe which is connected to the black valve to the back of the airbox.
    Any ideas?
    Thanks
    yes the pre/post 90 breather and over-run valve connections do differ depending where you put things and which car the airbox came from. for the 90spec the over-run comes off the bottom of the rubber boot and directly down to the rear of the airbox, pre-90 it comes off the plastic pipe instead. both years the breather is on the passenger side of the airbox though. if you have a mk1 airbox there is no over-run valve connection and breather is on the back when fitted to the driver side chassis leg
  5. _E_
    _E_ Forum Member
    Hi mate,
    I'm thinking of ordering this metering head boot one and making the front breather bigger to fit my over run valve pipe. Do you think that will create any issue?
    id just get the later 16v plastic pipe instead
  7. _E_
    _E_ Forum Member
    When say plastic pipe, which one do you mean?
  8. rubjonny
    The plastic pipe between the metering head rubber boot and the throttle rubber boot. The 90spec one has the overrun valve connection on the bottom of it
  9. _E_
    _E_ Forum Member
    Cheers mate
  10. _E_
    _E_ Forum Member
    Hi mate,
    Sorry to keep bothering you.
    Got into the car yesterday the battery was flat and notice that the instrument cluster leds were constantly on. I'm thinking that since I've plugged the headlights back in its knackered the headlight switch.
    Thanks
  11. rubjonny
    get the battery charged back up and see how it is before you start worrying too much
  12. _E_
    _E_ Forum Member
    Ok will do
  13. _E_
    _E_ Forum Member
    Just trying to figure out what has drained the battery as it is pretty much new and thought it must be the switch.
  14. rubjonny
    its possible for sure, once you have it all back up and running can do some more testing
  15. _E_
    _E_ Forum Member
    Well I got it running yesterday and flicked the headlight switch on and the engine stalled, thought it must be the voltage drawing to the headlights
  16. _E_
    _E_ Forum Member
    Hi mate,
    Got it all charged up everything working fine thanks.
    Just a couple of things.
    When pulling off in first it really kangaroos, am right in saying the clutch cable needs to correctly adjusted.
    Also really struggling with getting the right metering head boot. The one I ordered is to small the metering head I have is 12.5cm diameter. It seems different size to the rest of them.
    Thanks mate
  17. rubjonny
    could be the cable, you should have around 10mm of free play at the box end
    that sounds fine to me, whats the part number on the boot you have
  18. _E_
    _E_ Forum Member
    The part number is 027133357A
    Its only about 10cm diameter and metering head is 12.5cm.
  19. rubjonny
    thats a PL one, also listed to fit some 8v models so I guess thats why? the early KR one is 027133357B, late 051133357B
  20. _E_
    _E_ Forum Member
    Do you know if there are 2 types of the later kr boot?
