Fixing handbrake warning light on mk2 golf
Discussion in 'Mk2' started by saladman, Feb 15, 2023.
  1. saladman
    saladman Paid Member Paid Member
    West Yorkshire
    Been on my fix list for a while and thought I'd share a cheap and easy fix for this.
    Here's the bulb and holder from my mk2 dash. Instead of buying a new bulb I used an LED I already had. I used a 5mm white LED.
    Fairly easy to pull the bulb off and de-solder the wires from the terminals. I think one wire had actually snapped off the bulb at the glass rather than the bulb dying itself.
    I splayed the legs of the LED. Longer leg needs +ve feed, shorted is -ve / ground.
    I thought LED would fit inside the 'cage' plastic legs but it was a bit too big - you can see how the legs are pushed out and no longer parallel.
    Solution was to snip the plastic housing legs off and 'float' the LED in position. LED needs 3-3.2V, feed is ~12.5V.
    I used this LED resistor calculator to confirm resistor needed is 560 ohms and soldered one in series as shown above.
    Note that LEDs are polarised / need to be 'the right way around' regarding +ve and -ve voltage connections. We can re-use the existing loom connector since it clips into the white plastic. In this case, +ve voltage comes in on the 'flat' or right side in the photo above. I marked the side of the housing with red pen to remind me while soldering :)
    Note that I sanded the LED lens to diffuse the light output to make it more like the output from the original bulb.
    All back together and fairly happy with the result.
    I did a second light for another mk2 and found the white plastic part to be slightly different. Note the red pen mark to indicate +ve voltage feed :)
    Hope that helps anybody looking for a simple fix.
    dodgy, Matt Golf, AndyBa and 3 others like this.
    stickied as its a good tip for all the wee bulbs in older cars :thumbup:
    saladman likes this.
  3. John A Forum Member
    Good work, I did all mine, fiddly as hell but definitely worth it.
  4. Gti1990xyz Forum Member
    Aberdeen UK
    Saladman,
    excellent work. Indeed, if you do not use a resistor the LED will just be very bright then burn out quickly.
    I changed my bulb and bodged in a new bulb, perhaps when it fails I will do the LED switch.
    The brake light is for the handbrake and the low fluid level switch on the fluid reservoir for hydraulic brakes, I didn't know that and I thought i'd share incase others have overlooked that.
    A bit of other info I found, the LEDs on the instrument binnacle are LEDs apart from the full beam, it is just a bulb as blue LEDs did not exist at the time, so it is a clear lamp bulb with blue lampshade.
    allymac and saladman like this.
