Fuel pressure test
Discussion in 'Mk2' started by Rob8vGTi, Aug 16, 2023.
  1. Rob8vGTi Paid Member Paid Member
    Hi,
    What do I need to look for when conducting a fuel pressure test? I know my fuel pump should produce 5bar but when I turn the key off what should it be and for how long?
  2. PhilRyder
    I remember from my Porsche days which runs a similar k-jet system the pressure drop slowly after turning off the key. When I changed to EFi I had a dial which showed the pressure all the time which was 3 bar. After turning the ignition off the pressure would drop quite rapidly, probably a couple of minutes back to zero.
  3. rubjonny
    should be at least 2.6bar after 10 minutes
