Fusebox FAQ
Discussion in 'Electrical' started by rubjonny, Jul 30, 2010.
  1. sparrow Paid Member Paid Member
    Leamington Spa
    CE2
    Sort of helps. How do I know what's crossover and what's not?
    I've updated the mk2 section for plug D to say what feeds do what :)
    Otherwise a good way to tell is pull your x relay 18 out the fusebox, then test to see what feeds are still ignition live :thumbup:
    sparrow likes this.
  3. sparrow Paid Member Paid Member
    Leamington Spa
    Awesome, thanks. Looks like any of pins 8, 9 and 11 will work. :thumbup:
    yup will be perfik :)
    sparrow likes this.
  5. Dave
    Sligo, Eire
    Brilliant.
    And uber useful to me as I plough through the VWMS looms.
    Thank you.
    p.s. I can't be ar5ed to plough through all of your posts on this thread and tick thanks, so this will have to do.
    Uber regards,
    Your #1 fan,
    Dave.
    rubjonny likes this.
    you're very welcome dave :)
  7. Wayne the Jett New Member
    Hi can you help me please, I have a ce1 kr loom for my ce2 fuse box! Going of the numbers on the back off the fuse box's can you tell me which wires go where?
  8. rubjonny
    have a look at the link in my signature, g2krecuce2.pdf :)
  9. superferret420 New Member
    I think I am still confused with the CE1 box. My front wipers do not work but the water nozzles do. My back wipers work, but either I don't know how to use the washer back there, but it does not work. The stalk sticks a bit when using the front wash nozzle but using it for the rear wiper it works fine. suggestions?
  10. rubjonny
    sounds like the stalk may have packed in if its sticky
  11. superferret420 New Member
    Do the front and rear wipers run off the same relay?
  12. rubjonny
    they are both powered by the x-contact 17/18 relay, but for the actual operation of the wipers there is a separate front relay 19 or 99, and the rear is 20 or 72. the washers are fed direct from the stalk though
  13. superferret420 New Member
    Great! I am pretty sure we have spoken on Facebook and I am going to post this on the mk2 page in a minute also.
    update with pics!
    First off to whomever has followed my posts.... I was bored at a stop light and just rolled the dimmer switch back and forth, back forth,finally I see the LCD clock screen AND the light for the temp gauges working, move the dimmer some more and they are off. LOL! PROGRESS! Next, I followed the directions to remove the dash and get to the cluster to change the bulbs. Other than some or missing or rusted screws there were no problems. I disconnected the speedo cable, and was going to pull the "one" electric plug, only to find there were 2 of them for the cluster.? one on each side.
    headlight switch
    this is the relay I heard clicking.
  14. 8vmike New Member
    Hampshire
    Kjet thermoswitch wire
    Trying to find a wire break, as my cold start doesn't work (injector fine and thermoswitch)
    and following the fuseboard layout I have found that this wire
    18- red/blk- thermo switch for cold start valve (K-Jet f/inj) or digifant ECU pin 1
    is not in my PIN C connector (CE1)
    car is 8v 1984 GTI, if that helps
    just curious if there's a chance the wire is somewhere else? or my loom has been tampered with more than I thought
    cheers in advance if anyone can help
    Mike
  15. rubjonny
    do you at least have the spade connector on plug C for it? look in the back of the plug to see if the wire has been yanked out of the pin it can happen. on these you will have a 2 pin plug behind the fusebox with 2x red/black and 2x green/white wires, the C plug wire needs to plug into the red/black side leaving the green/white side empty.
    worst case you could tap the thermoswitch & 5th injector red/black to the 15a terminal on the starter motor if it has one. later kjet have the 5th injector here as standard anyway
  16. 8vmike New Member
    Hampshire
    Hi, you actually responded to my post on mk2 society to yesterday!
    But thanks again, I will be having a look at weekend
  17. blis Forum Member
    New South Wales
    Thank again John.. Wipers done, the rear demister has me beat, it says white and green on k connector, so I'm going in to have a look see, maybe it's connected to the wrong block
  18. rubjonny
    the heater is white on plug K, the green/white in the mk2 list refers to the wee wire with spade that feeds the heated wing mirrors :)
    blis likes this.
  19. Paul Kennea New Member
    Mk 1 fuse box and connectors
  20. cupracraig
    South West
    little bit confused on my electric window setup on the ce2 golf gti fusebox
    y1234 is as follows..1-2 unused / currently have a single connector on for electric windows...so perm live
    y3 battery live
    y4 bridges to 30b
    d9 seems to be 2 black wires, one with a connector on the end and the other is going off somewhere but seems to be indicated in the guide as 9 - blk/yel - electric window relay pin 86 (ignition live, fuse #14)..the wire looks too thin to feed the windows.
    So basically i have 1 free slot perm live and one used spot for windows live.
    The drain must be minimal but its obviously got the switches lit up all the time and i want to avoid that.
    any thoughts?
