Hi All, We have found some more items in our warehouse, rather than eBay them we are hoping they will be of use to someone on here P1 Accelerator Cable G2 Carb > July 1991 12.50 P2 Accelerator Cable G2 Injection > 1991 12.50 P3 Clutch Cable G2 1.6/1.8 1983> 12.50 P4 Clutch Cable Self Adj G2 1.6/1.8 18.00 P5 Clutch Cable Fit Kit G2 with self adj 5.00 P6 Bulkhead Repair Plate G1 11.00 P7 Engine Mount Rear G2 - 1.8GTI 8V ALL;16V >88 (>19-J-400000) 16.00 P8 Engine Mount Rear G2 FROM CHAS NO 19ZJW400001;G2 G60 24.00 P9 Engine Mount Front G2 ALL >87 24.00 P10 Engine Mount Front G2/J2 1.05/1.3/1.6/1.8 8V 88-92 MANUAL 24.00 P11 Gearbox Mount Rear G2/J2 84>92 >1.3 11.00 P12 Gearbox Mount Rear G2/J2 1.6-1.8 84> 11.00 P13 Cylinder Head Gasket Set G2/J2 16V 1.8 56.00 P14 Fuel Filter G2/J2>7/87 8.00 P15 Fuel Filter G2/J2 D/TD 8.00 P16 Oil Pump G2 84>92 1.6/1.8 8V 27.00 P17 Oil Cooler G2/J2 84>92 32.00 P18 Radiator G2/J2 DIESEL ONLY NOT TURBO 33.00 P18 Heater Matrix G2/J2 ALL 84-91 37.00 P19 Water Pipe Metal G2/J2 1.6/1.8 12.00 P20 Water Pipe Metal G2/J2 INJ/DIE/TD(NOT 16V) 12.00 P21 Fuel Vapour Seperator G2 86>91 25.00 P22 Fuel Pump Mount G2/J2 3.00 P23 Fuel Pump - In Tank G2/J2 1.8inj 8V/16V 84-92 20.00 P24 Exhaust Down Pipe G2/J2 1.6 36.00 P25 Silencer Centre G2/J2 1.8 CARB>MID 89 30.00 P26 Ball Joint G2/J2 >7/87 5.00 P27 Front Coil Spring G2/J2 84>1992 21.00 P28 Handbrake Cable G2/J2 GTI 8/88> 10.00 P29 Speedo Cable G2/J2 1.05-1.3 18.00 P30 Speedo Cable G2/J2 1.6-1.8 MAN NOT 16V 18.00 P31 GRILLE LIP SPOILER G2/J2 TWO HEADLAMP 9.00 P32 Manual Window Mech VW GOLF MK2 08/87>07/91 16.00 P33 Electric Window Switch 6 Terminal G2 8.00 P34 Blower Motor G2/J2 84-7/91 36.00 P35 Blower Motor Switch G2 7.20 P36 Fuel Pump Relay G2;J2;>87 24.00 P37 Fuse Box G2 91.20 Electric Window Mechanism Front RH ** NO MOTOR** 15.00 Golf MK2 1988 > 07/1991 Shock Strut Boot Front (plastic cup type) - G2 1.00 each. Oil Filter Wrench Chain Type 15.00 each. SKF Golf MK1/2/3 and Jetta Mk1/2 Front shock boot kit 8.00 each. Coil Spring Rear Golf Mk3 Estate 07/1993 > 04/1999 25.00 ETCH Primer 5L 25.00 Genuine VW Bagde Chrome MK2 Golf and Jetta 10.00 If you need anything let us know! We will no doubt find more as we go. Thanks
thats cool I did assume the price was too good to be true for a hella Sirguydo: I dont actually need any right now, and I even have a set of NOS hellas in my parts storage, thanks though! was just being greedy
I could get a hefty profit right now if i wanted as got them for a bargain I'm keeping them in the hope that one day my mk2 will be restored nice enough to deserve them. wont be for a long while though
More items added, some clearance and some we need to shift some excess stock. If you need anything, please message us!
REF PART FITMENT PRICE 1 Gear Lever Repair Kit G2/J2/G3 5.00 2 Gear Selection Rod -FR G2/J2-LONG METAL/PLASTIC 4.00 3 Gear Selection Rod - Side G2/J2 5 SPEED-SHORT PLASTIC 1.20 4 Accel Cable G2/J2 CARB 12.00 5 Accel Cable G2/J2 INJ 8V/16V 12.00 6 Handbrake Cable G2/J2 8/88> DRUMS 8.00 7 Handbrake Cable G2/J2/GTI/16V 84>7/88 8.00 8 Handbrake Cable G2/J2 GTI 8/88> 9.50 9 Speedo Cable 2/J2 1.6-1.8 MAN NOT 16V 18.00 10 Speedo Cable G2/J2 16V 24.00 11 GRILLE LIP SPOILER-PVC G2/J2 TWO HEADLAMP 5.00 12 GRILLE LIP SPOILER-PVC G2 GTI ETC;FOUR HEADLAMP 7.50 13 Parcel Shelf Strap G2 1.20 14 SEAT RUNNER CLIP-OUT G2 1.20 15 SEAT RUNNER CLIP-INN G2 1.20 16 DOOR MEMBRANE-FR G2 8.50 17 TAIL GATE STRUT G2 12.00 18 Blower Motor G2/J2 84-7/91 35.00 19 Wipe/Wash Switch G2 88-7/89 18.00 20 Wipe/Wash Switch MFA G2 GTI 90> 35.00 21 Fuse Box G2 90.00
