Help understanding faults
Discussion in 'Audi/SEAT/Skoda Chat' started by Ali Moenes, Dec 7, 2019.
  1. Ali Moenes New Member
    Hello people
    I'm fairly new to coding so bear with me please [​IMG]
    I have an Ibiza FR 2020 1.6 MPI
    I was fiddling with the steering response in the steering assistance module (44), I changed it to comfort and saved, and since then a lot of errors appear in the scan.
    The steering wheel became very hard as if there is no power steering. and this also messed other coding tasks i've done such as cornering.
    And finally I can not change anything in the steering assistance module, whenever I try to change anything and apply --> (22) function cancelled, marginal conditions have not been met.
    Example of the faults:
    Here is a link to the history https://drive.google.com/file/d/1MH8FmwR40xo23kFDzsNrSniKuRdybZOG/view?usp=sharing
    Here is the latest error log:
    OBDeleven data log
    Date: 2019-12-07 15:04
    VIN: VSSZZZKJZLR020301
    Car: Seat Ibiza FR
    Year: 2020
    Body type: Hatchback
    Engine: CWVA 81 kW (110 HP) 1.6 l
    Mileage: 3446 KM
    03 Brakes 1
    System description: ESC_base
    Software number: 2Q0614517AE
    Software version: 0242
    Hardware number: 2Q0614517L
    Hardware version: H13
    Serial number: 08505898180808
    ODX name: EV_Brake1BOSCHESPMQBA0
    ODX version: 004036
    Long coding: 530D4C573543CAAD32FFAC1634DB22A649124926226A245844 542254452C4465924892644456241A222A442AA22996431594 69C2A8
    Trouble codes:
    U111300 - Function limitation due to received malfunction value
    Intermittent
    Date: 2019-12-06 12:29:54
    Mileage: 3330 km
    Priority: 3
    Malfunction frequency counter: 10
    Unlearning counter: 213
    Unknown ambient data: 0000000200A90000000001160000
    static
    Date: 2019-12-06 15:02:59
    Mileage: 3337 km
    Priority: 3
    Malfunction frequency counter: 3
    Unlearning counter: 173
    Unknown ambient data: 0007000240A40000000100000000
    U042300 - Invalid Data Received From Instrument Panel Cluster Control Module
    static
    Date: 2019-12-06 03:29:55
    Mileage: 3330 km
    Priority: 3
    Unlearning counter: 163
    Unknown ambient data: 0000000240B40000000001000000
    44 Steering Assistance
    System description: TRW_G4L_MQBA0
    Software number: 2Q1909144M
    Software version: 6041
    Hardware number: 2Q1909144F
    Hardware version: 611
    Serial number: 1309413CB2K20320820
    ODX name: EV_SteerAssisTRWG4LMQBA0
    ODX version: 011016
    Long coding: 010000000000000001000201010001010000010001
    Trouble codes:
    U112300 - Databus error value received
    Intermittent
    Date: 2019-12-06 03:29:43
    Mileage: 3330 km
    Priority: 6
    Engine speed: 0 1/min
    Vehicle speed: 0 km/h
    System status: Reset
    Terminal 15 status: On
    Voltage terminal 30: 12.87 V
    Power steering current consumption: 0.5 A
    max.value: 16.5 A
    End stage temperature: 33 °C
    Steering assistance, engine output: 100 %
    Engine angle: 276 °
    Electric motor speed: 0 1/min
    Steering assistance, target engine torque: 0.0 Nm
    ---: 0.9 Nm
    static
    Date: 2019-12-06 03:29:48
    Mileage: 3330 km
    Priority: 6
    Vehicle speed: 50 km/h
    System status: Cut_in
    max.value: 16.5 A
    Engine angle: 276 °
    Steering assistance, target engine torque: 0.1 Nm
    ---: 0.8 Nm
    B200FF0 - Internal malfunction
    Intermittent
    Date: 2019-12-06 15:23:04
    Mileage: 3337 km
    Priority: 5
    Unlearning counter: 165
    System status: Waiting for start request
    Terminal 15 status: Off
    Voltage terminal 30: 12.11 V
    max.value: 0.5 A
    End stage temperature: 215 °C
    Engine angle: 0 °
    ---: 0.1 Nm
    B7 Access Startsystem Interface
    System description: VWKESSYMQB
    Software number: 3Q0959435N
    Software version: 1307
    Hardware number: 3Q0959435N
    Hardware version: 037
    Serial number: 0520812458
    ODX name: EV_KessyHellaMQBAB
    ODX version: 004052
    Long coding: 112E0E0703
    Trouble codes:
    static
    Mileage: 3330 km
    Priority: 6
    Malfunction frequency counter: 2
    Terminal_15_Kessy_specified_value: On
    Terminal_15_Kessy_actual_value: On
    Terminal_15_central electric_actual_value: On
    Terminal_15red_Kessy_specified_value: On
    Terminal_15red_Kessy_actual_value: On
    Terminal_S_Kessy_specified_value: On
    Terminal_S_Kessy_actual_value: On
    Terminal_S_central electric_actual_value: On
    Terminal_50_Kessy_specified_value: Off
    Terminal_50_Kessy_actual_value: Off
    ZAT_pressed: Off
    Park selector lever position: Engaged and locked
    Request active: Condition not met
    Enabling steering column lock: Condition not met
    Enabling immobilizer: Condition not met
    No active error mode: Condition met
    Key signature validity: Condition met
    ---: 12.851 V
    Driver information key position copy workshop: not active
    Driver information, roll warning: not active
    Driver information, emergency shutdown: not active
    Internal_key_position: no_message
    Driver information comfort switching: not active
    Vehicle speed: 0.0 km/h
    Engine speed: 0.0 1/min
    ---: Vehicle unlocked
    Approach to the inside: not active
    Actuation to the inside: not active
    Approach to the outside: not active
    Actuation to the outside: not active
    Pulling actuation, outside door handle: not active
    Coding information: coded
    Coding information: Not coded
    Driver door: Open
    Front passenger door: Closed
    Left rear door: Closed
    Right rear door: Closed
    Active_LF_scans: Init
    ID sensor 1 authentication, status: No response
    ID sensor 2 authentication, status: No response
    ID sensor 3 authentication, status: No response
    ID sensor 4 authentication, status: No response
    SPN_Byte 0: 0
    SPN_Byte 1: 0
    SPN_Byte 2: 0
    Probably better to have a word with the authors of the software you're trying to use, possibly it doesn't support your car fully. certainly all the errors its coming back with suggest some kind of coding fault
