High idle got me stumped
Discussion in 'K-Jetronic OEM injection' started by Bazboy, Mar 21, 2014.
  1. Bazboy Forum Member
    Hi Peeps
    Bit of a weird one, my car idles at 1500 rpm, doesnt hunt and is a smooth idle. Ive tried adjusting the idle screw and 1500 is the lowest it will go..... that is unless you disconect the isv, then it happily sits at 900rpm but if you rev it fails to catch and stalls so the isv is needed.
    So i figured the isv just needs to put into setup mode.... alas in setup mode it idles at 2500 rpm, and will not go any lower unless you take it out of setup mode.. :(
    I really cant figure out what is wrong, fingers crossed one of the kind peeps on here will know :)
    Thanks Dan
  2. GVK
    What car/engine etc?
  3. Bazboy Forum Member
    Haha sorry thats a pretty big bit of missing info.
    Its an Abf in a mk2 jetta running kjet.
  4. MUSHY 16V
    aberdeen
    did you split the plug at the coil before adjusting the idle screw ?
  5. Bazboy Forum Member
    Nope, the isv control unit failed so whilst i found a replacement i upped the idle to stop it stalling, but now with a work control unit i cant get the idle down.
  6. GVK
    Sounds like the ISV is stuck open.
    Have you had a look at 'rubjonnys' 16v set up guide, tested the temp senders etc?
  7. MUSHY 16V
    aberdeen
    You have to split the plug with the red/blk wire under the coil
    To set the idle ;)
  8. GVK
    Here's the original text I did about 12-13yrs ago..I feel old now.
    The pics with my dirty fingers on don't seem to work anymore!! [sad]
    MUSHY 16V likes this.
  9. Bazboy Forum Member
    I have tried to adjust the idle with the spade disconected but the idle climbs to 2500 and wont come down.
    I too thought isv could be buggered so i tried another and problem still remained :(
    I had a read throught the 16v setup guide originally which is where i learned of the isv setup mode.
    Cant think if anything else it could be.
  10. MUSHY 16V
    aberdeen
    When was the last time yours had a 16v in it Gary
    I can't remember the last time I had mine running lol
  11. MUSHY 16V
    aberdeen
    You could try cleaning the isv worth a try
    The one on mine would stick sometimes and idle at 2500 then go back to normal
  12. GVK
    A long time ago.
    I'm trying to picture how all the pipes,bits & bobs go on them. lol
  13. GVK
    I don't understand how disconnecting the red/black wire makes it rev higher, as i always thought that takes the power from the ISV, unless it's pulling air in from elsewhere?
  14. Bazboy Forum Member
    I cant figure it out either, all my vacuum lines are good and im pretty certain its not getting air from anywhere it shouldnt.
  15. GVK
    How about the Y shape pipe the ISV connects to? All ok?
    Does the throttle flap close fully?
    Has the throttle stop been wound out?
    I guess that must be all ok if if it idles at 900 with the ISV disconnected.
  16. Bazboy Forum Member
    Yea all seemed fine when checking earlier, i will have a double check tomo after work but like you say its weird how it idles nicely with no isv :/
  17. Bazboy Forum Member
    Okay i have double checked and all seems fine and dandy leaving me well and truly stumped!
  18. KeithMac Forum Junkie
    Kazakhstan
    Have you got the correct ISV?, the Digi1's look exactly the same but work differently (they are closed at 25% duty cycle, when disconnected they open again as a fail safe). Sounds like you have a G60 valve fitted?.
  19. Bazboy Forum Member
    Well i have 2, one bought from a chap on here and tge other from when it was 16v kr and both do the same :/
  20. MUSHY 16V
    aberdeen
    mine sometimes had the throttle not close right to the stop and not make the switch
    was soon fixed with a good clean and spray of oil
    the throttle stop on mine still has the yellow paint on it do they all have that?
