High idle issues when cold
Discussion in 'K-Jetronic OEM injection' started by mk2 nas, Jun 11, 2016.
  1. mk2 nas Paid Member Paid Member
    Northamptonshire
    Ok all clear now.:thumbup:
  2. mk2 nas Paid Member Paid Member
    Northamptonshire
    This is the relay I found with the other bits,took cover of to have a look inside seems good enough.
  3. mk2 nas Paid Member Paid Member
    Northamptonshire
  4. mk2 nas Paid Member Paid Member
    Northamptonshire
    Relay sorted,high idle issue still a problem getting quite annoying now.next step is to clean out throttle body.
    And change the Venturi,y piece.just ordered one from derour ltd,after stumbling across it on another forum,thanks to RJ.
    ;):thumbup::clap:
  5. mk2 nas Paid Member Paid Member
    Northamptonshire
    Been looking into high idle,removed aav placed in the freezer and it opens up to a small triangle
    Poss 1/8 or 1/10 of area then heated it up from freezing Untill it was hot(hairdryer)held it up to
    The light it had closed up almost complete but I can just see a chink of light(hot)is this the norm?
    Also had throttle body off cleaned thorough,but noticed the screw was set that allows slight light(air) through
    Should this be at full closed position?this was the w.o.t butterfly.:thumbup:
    not sure on the AAV, with the throttle body do you mean the throttle stop? If you suspect its been messed with check the haynes for the reset procedure. I only have the mk2 haynes on my peecee which may not be the same procedure. I can have a look in my mk1 haynes later for you but its definitely worth getting yourself one, its the brown one you want :thumbup:
  7. mk2 nas Paid Member Paid Member
    Northamptonshire
    Hi,whatever ive done it's not idling high anymore,what I did was..
    Removed throttle body and cleaned it,
    Removed aav and adjusted the cold hole set size(slightly)
    New seal at throttle body.
    New idle screw rubber(although tbh is wasn't that bad).
    If anything my idle is too low now but it's easier to speed up.than find a racing
    Problem so all is good for now,
    But being 34yr car I'm sure to be posting my next issue soonlol
    Big thanks rj and j,o and others without the info ive had of this forum I doubt it would be on the road yet:thumbup: image.jpg she,s about finished but are they ever really finished.
  8. rubjonny
    fingers crossed you have it cracked :thumbup:
