Hmmm, just recorded a VHS to DVD, Put the DVD in the PC and it can't see anything...
Discussion in 'Computers and Consoles' started by A.N. Other, Feb 4, 2012.
    What am I missing? [:$]
    Drivers?
    Software to read DVD?
  2. Admin Guest
    Was there any option to finalise the dvd?
    Yep, option given and it did it when stopping the recording process.
    Only hint I have is the PC appears to be trying to read a CD, not a DVD on the auto start.
  4. Admin Guest
    Hmmm sounds like it's not recognising it for sure. Could just be a fussy dvd rom drive that can't read certain types of recordable DVD media. Try it on another pc if you can
  5. mat-mk3
    mat-mk3 Administrator Admin
    Did it make it a proper DVD? Not like a div-x and you need the codec?
    How can I find out? It was as straightforward as pressing record and stop, and it will play on the DVD ok.
  7. mat-mk3
    Get the manual out?:lol:
  8. Admin Guest
    Can you stop the autoplay and right click and explore the disc or is it not simply even getting to that point?
  9. Admin Guest
    You have a Dell too don't you? I remember that Dell used a DVD drive that didn't like DVD-R's a while back in the inspirons. If you look in Device manager and see what model of drive you have and also let us know what the dvd media is. That could be the issue if it's not even reading the disc properly.
    If it's recognising it as something else then as Mat said it could be a Div-x format or something that you need codecs for.
    Tried it again. Seem to be in business [8D]
    Now have 2 folders on the DVD:
    VIDEO_RM - has one video file inside, 'VIDEO_RM'
    VIDEO_TS - has three video files inside, 'VIDEO_TS', 'VTS_01_0' & 'VTS_01_1'
    Which one to pick / convert to Avi - to then edit in Moviemaker?
    VTS_01_1 is the largest file by miles, assume that's it.
    => converting it to Avi via Prism.
  12. Collie Forum Junkie
    have you tried to use the dvd in a normal dvd player? pulugged into the tv?
  13. Collie Forum Junkie
    is the dvd drive assigned to a region via
    control panel > device manage r> dvddrive > properties >tab region
  14. A.N. Other Banned after significant club disruption Dec 5th 2
    Looks good, already set to region 2.
    Got some more to do today, so will see how I go :thumbup:
  15. mat-mk3
    Whats the quality like coming off a VHS?
    I have some to do but its one of those end of the road jobs...
  17. mat-mk3
    Wow, Thats actually quite good!
    Short play was a better quality setting i think, But obviously longer to convert.
    I cant see much wrong with that to be honest.
    I have a load of family VHS to convert one day.
  18. A.N. Other Banned after significant club disruption Dec 5th 2
    I'm about to convert another DVD. To get it into Moviemaker, I need to convert it from DVD format to avi, mpg, wmv, flv, mp4 etc.
    The linked vid was done on AVI.
    Is one of those ones weak on quality? What should I best choose?
  19. Admin Guest
    I record onto DVD-RAM (same as DVD really but erasable) in short play (PCM sound format too) then encode it using TMPGE Xpress 4.0. There you can convert it into any format and quality. I've had great results.
    Judging from last night's efforts, it went up onto youtube at 480p.
    I think I need to understand & optimise this further before doing anything more, as anything less than 720p or 1080p seems careless these days.
    Any experiences on the max that can be got from VHS though?
