HOW TO: Fit Adjustable camber/toe EZ-Shims to the rear beam / stub axle.
Discussion in 'Chassis' started by Nige, Nov 20, 2012.
  1. rubjonny
  2. daNpy Forum Member
    NL
    Sorry to intervene, but why are the Polo/Ibiza stub setups stronger?
  3. rubjonny
    the stubbies are chunkier, and the bearings are larger. tbh for normal usage it makes no odds, though it does mean disc swaps are cheaper in future as its a separate hub/disc setup
  4. daNpy Forum Member
    NL
    I also see the bearing is tightened with 175 Nm. The bearings on my MK2 need to be tightened by hand, then turned counter clockwise until the pin fits.
    Good to look into then when I need to replace something on the rear anyway :)
  5. rubjonny
    tbh the cheaper disc cost is pretty well offset by the massive cost of the kits these days now everyone has cottoned on to it :lol:
    KeithMac and daNpy like this.
  6. KeithMac Forum Junkie
    Kazakhstan
    I was taught to tighten the hub bearing up then back it off until you feel it "give", hard to explain really!.
    Regardless there is very little preload on it.
  7. daNpy Forum Member
    NL
    Yeah thats more or less what I meant. At least the pin has to fit anyway and the preload should be very low indeed.
    KeithMac likes this.
  8. rubjonny
    there is a factory torque setting to use with brand new bearings to ensure they're seated, then you back off till you can just about shove the washer without leverage. main thing is you dont go too mad, have bearing overheat and wheel fall off :lol:
