How to ...Fitting Focus/Seat Short master cylinder to mk2 servo modification for 1.8t
Discussion in 'Chassis' started by fasteddie, Sep 5, 2014.
  1. Neil_Ireland Forum Member
    Thanks, I presume there’s no issue blanking off the two unused ports?
    Nope, often did it, you have to even when fitting a 16v cylinder to an 8v. Obviously you need to bleed them before closing them fully.
    bri likes this.
  3. rubjonny
    if you buy new 22mm master from VW it would be a 4 port and is supplied with 2 blanks. aftermarket often come with the blanks as well. otherwise either use bleed nipples or source blanks from VW/ebay
  4. Neil_Ireland Forum Member
    Thanks for all the advice folks.
    I have a pair of blanks on the way from vw heritage.
    Will probably go with the trw transporter master cylinder.
    Need to remove the servo for a refurb first.
  5. BRI
    bri Forum Member
    Ireland
    Maybe this is my problom! Never thought to bleed the blank port, I only have one port blanked though being a corrado.
    I didnt remove any calipers to bleed, never have had to do that before? I used a pressure bleeder and vacumn at each corner also , haven't tried the pedal method as I didnt have a willing participant to hand
  6. BRI
    bri Forum Member
    Ireland
    Thanks for your help, these look like they should fit the bill perfectly !
  7. rubjonny
    usually dont need to remove calipers but it can help get rid of any stubborn bubbles, helps to pre-bleed calipers as well if you're fitting them empty or have drained down system completly
  8. Neil_Ireland Forum Member
    For the non technical what’s the procedure to pre-bleed calipers? I have all mine removed.
  9. rubjonny
    just fill them with brake fluid on the bench before you fit, a syringe and an old cut off brake hose is handy for this job (insert syringe into the cut end of brake hose and fill caliper till fluid comes out the bleed nipple) with the rear calipers make sure you havent wound the pistons all the way in as far as they can go, you cant bleed them like that
    Neil_Ireland likes this.
