HOW TO: Set System & WUR fuel pressure
Discussion in 'K-Jetronic OEM injection' started by gti_kev, Jan 5, 2006.
  1. theboymike Forum Junkie
    England
    Nice video find :thumbup:
  2. dogzila Forum Member
    Example my wur pressure is 3.4 bar, and I add shim, so control pressure rise or fall?
  3. rubjonny
    wur pressure is changed using the allen key, its the system pressure you adjust with shims. this needs to be set at 5 bar.
    see point 5:
  4. chrismc Forum Junkie
    Would I be right in thinking a 2L conversion would have the effect of leaning the idle mixture due to extra cylinder filling?
    Is this the same throughout the range?
    System pressure is spot on with control pressure previously set to 48psi (whilst the KR motor was fitted)
    Weighing up whether a setup is going to liberate more go? Feels great as is- but worth the spend if further wur and ignition tweaks are required. Currently running 9degs of advance..
  5. rubjonny
    changing the engine will require tweaks to the co mixture one way or another. apart from that a std kr setup should be able to handle a 2.0 no problem at all, as long as everything is working right
    engine swap alone shouldn't effect the pressures if thats what you mean
  7. chrismc Forum Junkie
    Thanks John
    I tweaked the mixture up a knats as the tickover was a tad lumpy. Sorted that out a treat. Will check and adjust co at next MOT.
    I guessed that the pressures would all remain static- but wondered if control pressure requires further adjustment from 48psi?
    Pulls cleanly as it is but no idea on whether afr needs further tweaking due to the bigger capacity. From what you are saying I'm guessing the fact the control pressure has already been tweaked and mild spec should mean it's ok!
  8. rubjonny
    yeah the system is closed so it shouldnt make any difference changing the engine. you may need to tweak the wur, thuis comes down to your afrs. ideally the wur should be set properly on a rolling road, 48psi is just a guesswork figure, will add a little extra fuel but it wont be correct for everyone
  9. chrismc Forum Junkie
    Cool.
    I think il book it in for a setup to give a baseline figure before deciding on my next mods...
    Will be a while seeing as the first mini-mc is due on the 7th! VWs will be taking a back seat for a while!:lol:
  10. dogzila Forum Member
    normal pressure is 4.7-5.4, I want to rise pressure to 5.5 bar, did this increase or decrease control pressure (WUR)?
  11. rubjonny
    id assume it would raise the control pressure as well, since from what i understand the wur reduces pressure by x amount from system pressure if that makes sence? you would want to have a pressure gauge plugged in to tweak the system pressure anyway so you can check for yourself if control pressure is effected :)
  12. dogzila Forum Member
    I read in vwvortex, when you increase system pressure, then also you have to increase control pressure (WUR) for better divebility (lean mixture), so control pressure decrease.. :)http://forums.vwvortex.com/showthread.php?695555-Increasing-total-fuel-system-pressure-CIS&highlight=System+Pressure+cis f
  13. rubjonny
    oh i see what you mean now! yeah you would want to check the afrs afterwards and adjust the wur to suit. its not something you can just mess about with an arbituary fgure as all cars are different. just happens that 48psi does work well when everything else is std. you may have to adjust this depeindign on state of tune etc
  14. chrismc Forum Junkie
    Idle co reset today. Was a tad rich with idle co at 10% after my quick twist on the mixture screw post engine swap[:$]
    Seems happy enough on 2.5% now.
    Will book in for a setup at Stealth and see where it's at:)
  15. dragov New Member
    I've recently managed to buy a tester for K-Jet to test the WUR and fuel system pressure on my 16V KR, and i noticed that the control pressure goes directly to 3.4 bar (when cold), instead of starting from 1.5bar and going slowly to 3.4.
    Could it be the bimetallic spring boken? I want to mention that the first time when i tested the pressure, the control pressure was at 5 bar, and i used the drilling method to adjust it to 3.4
  16. rubjonny
    something definitly isnt right, cant hurt to take it off and split it down to see whats what. there is a wee mesh filter on one of the ports this might be gunged up
    MUSHY 16V likes this.
